Recommended use of colors with additional information about piping, duct-work, etc.
RED = FIRE PROTECTION | ALARM BOXES |
BLANKET BOXES | |
BUCKETS | |
EXTINGUISHERS | |
HOSE LOCATIONS PUMPS | |
HYDRANTS | |
SIRENS | |
EXIT SIGNS | |
SAFETY CANS AND CONTAINERS FOR FLAMMABLE LIQUIDS | |
YELLOW = CAUTION | FRONT ENDS OF LOCOMOTIVES |
HAND RAILS | |
BULLDOZERS | |
TRACTORS | |
EXPOSED EDGES OF PLATFORMS AND CURBING | |
GUARDRAILS | |
PILLARS & POSTS | |
COLUMNS | |
FORK LIFTS | |
DOORWAY PROJECTIONS | |
LOW BEAMS | |
PULLEY BLOCKS AND CRANES | |
CONVEYORS | |
CAUTION SIGNS | |
PURPLE = RADIATION HAZARDS | |
ORANGE = DANGEROUS MACHINERY PARTS (WHICH MAY CUT, CRUSH OR SHOCK) | EXPOSED PARTS OF PULLEYS |
GEARS | |
ROLLERS | |
CUTTING DEVICES | |
POWER JAWS | |
SAFETY STARTING BUTTONS | |
INSIDE OF MOVABLE GUARDS | |
ELECTRICAL SWITCH BOXES | |
FUSE BOXES | |
BLUE = WARNING AGAINST STARTING, OR MOVING EQUIPMENT UNDER REPAIRS | LADDERS |
SCAFFOLDING | |
ELECTRICAL CONTROLS | |
ELEVATOR STARTING CONTROLS | |
BOILERS | |
DRYERS | |
MACHINERY, ETC. | |
GREEN = SAFETY DESIGNATES LOCATION | FIRST AID DISPENSERS |
FIRST AID KITS | |
GAS MASKS | |
STRETCHER | |
SAFETY SHOWERS | |
OTHER SAFETY EQUIPMENT | |
SAFETY INSTRUCTION SIGNS | |
IDENTIFICATION OF PIPES |
RED = FIRE PROTECTION AND SPRINKLER PIPING | POST INDICATOR VALVES FOR SPRINKLER SYSTEMS |
YELLOW OR ORANGE - DANGEROUS MATERIALS | FLAMMABLE LIQUIDS GASOLINE, NAPHTHA, FUEL OIL, ETC. |
POISONOUS GASES CHLORINE GAS, AMMONIA, SULPHUR DIOXIDE, ETC. | |
CORROSIVE LIQUIDS ACIDS, ALKALIS | |
STEAM, WATER, OR AIR AT HIGH TEMPERATURES AND PRESSURES | |
GREEN = MATERIALS LOW IN TEMPERATURES AND PRESSURES: NON-POISONOUS NON-FLAMMABLE | FIRST AID DISPENSERS |
FIRST AID KITS | |
GAS MASKS | |
STRETCHER | |
SAFETY SHOWERS | |
BLUE = PROTECTIVE MATERIALS FOR PREVENTING OR REDUCING HAZARDS OF DANGEROUS MATERIALS | INCLUDES SPECIAL GASES TO COUNTERACT OR NEUTRALIZE POISONOUS FUMES, WHICH ARE PIPED FOR RELEASING IN EVENT OF DANGEROUS PROTECTIVE MATERIAL OTHER THAN FIRE PROTECTION |
Standards
- ANSI Z535.1 American National Standard for Safety Colors
- ISO 3864 Graphical symbols -- Safety colors and safety signs
• Measurements and Instrumentation
Measurement and instrumentation strategies.
• Risk, Reliability and Safety
CE Marking
Verifies that a product is designed to the appropriate standards according the European Machine Directive.
Chemicals Hazard Rating System
The National Fire Protection Association (NFPA) hazard system for chemical materials.
Calculate ring (or pipe) diameter expansion or contraction when temperature changes.
Color Mixing Theory
Subtractive and additive color mixing.
Factors of Safety - FOS
Factors of Safety - FOS - are important in engineering designs.
Fire-Stop Ratings
F-rated, T-rated and L-rated fire-stop systems.
Fluids - Identity Colors
Identifying colors used for fluid piping systems.
Gases - Dangerous Concentration Levels
Dangerous vs. tolerable concentration levels for some industrial gases.
Hazardous Areas - European Classification Standard
European hazardous area classification with zones, protection types, temperature codes and codes.
Hazardous Areas - North America Classification
North American hazardous locations classification with classes, divisions and groups
Hazardous Areas - Protection Techniques according European IECEx
Hazardous areas protection techniques - explosion proof, flameproof and intrinsically safe.
Heating Systems - Safety Valve Size vs. Boiler Power
High Pressure Steam Systems - Safety Valve Capacities
Sizing safety valves according boiler output power in high pressure systems (kW and Btu/hr)
IP - Ingress Protection Ratings
IP - Ingress Protection rating is used to specify the environmental protection - or electrical enclosure - of electrical equipment.
Low Pressure Steam Safety Valves - Capacities
Sizing safety valves after boiler output power in low pressure systems (kW and Btu/hr).
Pilot Operated Safety Valves in Liquid Systems
Calculate pilot operated relief valves in liquid systems.
Safety Valve Standards
The most common used safety valve standards in Germany, UK, USA, France, Japan, Australia and Europe.
Safety Valves in Saturated Steam Systems
Calculate safety valves in saturated steam systems
Spring Operated Safety Valves in Liquid Systems
Calculate spring operated relief valves in liquid systems.
Water Sprinkler Protected Areas and Hazard Classification
Maximum fire sprinkler protected area vs. classification and construction.
