Safety Valves in Saturated Steam Systems
The minimum discharge area of a relief safety valve in a steam system can be calculated as
A = m / (51.5 kd kbp P1/2) (1)
A = minimum discharge area (Square Inches)
m = relieving capacity (Lbs. per Hour)
kd = discharge coefficient - 0.975
kbp = back pressure coefficient - 1.0 for atmospheric discharge systems
P = relieving pressure (psia) - set pressure (psig) + over pressure (psig) + atmospheric pressure (14.7 psia)
• Control Valves and Equipment
Factors of Safety - FOS
Factors of Safety - FOS - are important in engineering designs.
Heating Systems - Safety Valves Size vs. Boiler Power
High Pressure Steam Systems - Safety Valve Capacities
Sizing safety valves according boiler output power in high pressure systems (kW and Btu/hr)
Low Pressure Steam Safety Valves - Capacities
Sizing safety valves after boiler output power in low pressure systems (kW and Btu/hr).
Pilot Operated Safety Valves in Liquid Systems
Calculate pilot operated relief valves in liquid systems.
Spring Operated Safety Valves in Liquid Systems
Calculate spring operated relief valves in liquid systems.
