Spring Operated Safety Valves in Liquid Systems
The minimum discharge area of a spring operated relief safety valve in a liquid system can be calculated as
A = q SG1/2 / (28.14 Kbp Kvisc dp1/2)                                    (1)
A = discharge area (Square Inches)
q = relieving capacity (Gallons per Minute)
SG =Specific Gravity of the fluid
Kbp = capacity correction for back pressure - 1.0 for atmospheric pressure systems
Kvisc = correction factor due to velocity - 1.0 for most water systems
dp = differential pressure - set pressure (psig) + over pressure (psig) - back pressure (psig)
Pressure Ratings of Pipes and Fittings
Factors of Safety - FOS
Factors of Safety - FOS - are important in engineering designs.
Heating Systems - Safety Valve Size vs. Boiler Power
High Pressure Steam Systems - Safety Valve Capacities
Sizing safety valves according boiler output power in high pressure systems (kW and Btu/hr)
Low Pressure Steam Safety Valves - Capacities
Sizing safety valves after boiler output power in low pressure systems (kW and Btu/hr).
Pilot Operated Safety Valves in Liquid Systems
Calculate pilot operated relief valves in liquid systems.
Relief Valves - Length of Vent Pipes
Calculate length of safety valves vent pipes.
Safety Relief Valves - Capacity vs. Pressure
Maximum safety valve free air relief capacity.
Safety Valve Standards
The most common used safety valve standards in Germany, UK, USA, France, Japan, Australia and Europe.
Safety Valves in Gas and Vapor Systems
Calculating relief valves in gas and vapor systems.
Safety Valves in Saturated Steam Systems
Calculate safety valves in saturated steam systems
