Pilot Operated Safety Valves in Liquid Systems
The minimum discharge area of a pilot operated relief safety valve in a liquid system can be calculated as
A = q SG1/2 / (36.81 Kvisc dp1/2) (1)
A = discharge area (Square Inches)
q = relieving capacity (Gallons per Minute)
SG = Specific Gravity of the fluid
Kvisc = correction factor due to velocity - 1.0 for most water systems
dp = differential pressure - set pressure (psig) + over pressure (psig) - back pressure (psig)
• Control Valves and Equipment
• Pressure Ratings
API - Valve Standards
An overview of the American Petroleum Institute - API - valve standards.
BSi - British Standard Valves
An overview of BSi - British Standard institute valve standards.
DIN - Valve Standards
An overview of DIN - Deutsches Institut für Normung - valve standards.
Factors of Safety - FOS
Factors of Safety - FOS - are important in engineering designs.
Heating Systems - Safety Valves Size vs. Boiler Power
High Pressure Steam Systems - Safety Valve Capacities
Sizing safety valves according boiler output power in high pressure systems (kW and Btu/hr)
Low Pressure Steam Safety Valves - Capacities
Sizing safety valves after boiler output power in low pressure systems (kW and Btu/hr).
Relief Valves - Length of Vent Pipes
Calculate length of safety valves vent pipes.
Safety Relief Valves - Capacities vs. Pressure
Maximum safety valve free air relief capacity.
Safety Valve Standards
The most common used safety valve standards in Germany, UK, USA, France, Japan, Australia and Europe.
Safety Valves in Gas and Vapor Systems
Calculating relief valves in gas and vapor systems.
Safety Valves in Saturated Steam Systems
Calculate safety valves in saturated steam systems
Spring Operated Safety Valves in Liquid Systems
Calculate spring operated relief valves in liquid systems.
Steam Safety Valves - Installation Guide
Guidelines to safety steam valves installation.
