BSi - British Standard Valves
BSi - British Standard institute valve standards:
  • BS 341-1:1991
    Transportable gas container valves. Specification for industrial valves for working pressures up to and including 300 bar (REPLACED by BS EN 14189:2003) , BS 341-3:2002) , BS EN 849:1997) , BS EN ISO 13340:2001) , BS EN ISO 14246:2001) , BS 341-4:2004)
  • BS 341-2:1963
    Transportable Gas Container Valves. Valves with Taper Stems for Use with Breathing Apparatus. (REPLACED by BS 341-1:1991) , BS EN 849:1997) , BS EN ISO 12209-1:2001) , BS EN ISO 12209-2:2001) , BS EN ISO 12209-3:2001)
  • BS 341-3:2002
    Transportable gas container valves. Valve outlet connections
  • BS 341-4:2004
    Transportable gas container valves. Pressure relief devices
  • BS 759-1:1984
    Valves, gauges and other safety fittings for application to boilers and to piping installations for and in connection with boilers. Specification for valves, mountings and fittings
  • BS 1123-1:1990
    Safety valves, gauges and fusible plugs for compressed air or inert gas installations - Code of practice for installation
  • BS 1212-1:1990
    Float operated valves - Specification for piston type float operated valves (copper alloy body) (excluding floats)
  • BS 1212-1:1990
  • BS 1212-3:1990
    Float operated valves - Specification for diaphragm type float operated valves (plastics bodied) for cold water services only (excluding floats)
  • BS 1212-4:1990
    Float operated valves - Specification for compact type float operated valves for WC flushing cisterns (including floats)
  • BS 1552:2004
    Specification for open bottomed taper plug valves for 1st, 2nd and 3rd family gases up to 200 mbar
  • BS 1570:1960
    Flanged and but weld-welding end steel plug valves for the petroleum industry (excluding well -head and flow-line valves)
  • BS1655:1976
    Flanged automatic control valves for the process control industry (face to face dimensions)
  • BS 1735:1966
    Flanged cast iron outside-screw-and-yoke wedge gate valve, class 125, sizes 1 1/3 in to 24 in, for the petroleum industry
  • BS 1868:1975
    Specification for steel check valves (flanged and butt-welding ends) for the petroleum, petrochemical and allied industries
  • BS 1873:1975
    Specification for steel globe and globe stop and check valves (flanged and butt-welding ends) for the petroleum, petrochemical and allied industries
  • BS1952:2000
    Copper alloy valves for general purposes
  • BS1953:2000
    Copper alloy check valves for general purposes
  • BS1963:1990
    Specification for pressure operated relay valves for domestic, commercial and catering gas appliances
  • BS 1968:1953
    Specification for floats for ball valves (copper)
  • BS2060:2000
    Copper alloy screw down stop valves for general purposes
  • BS2080:1995
    Specification for face to face, center to face, end to end and center to end dimensions of valves
  • BS 2456:1990
    Specification for floats (plastics) for float operated valves for cold water services
  • BS 2879:1980
    Specification for draining taps (screw-down pattern)
  • BS2995:1966
    Cast and forged steel wedge gate, globe, check and plug valve, screwed and socket welding, sizes 2 in and smaller, for the petroleum industry
  • BS 3457:1973
    Specification for materials for water tap and stop valve seat washers
  • BS 3464:2000
    Cast iron wedge and double disk gate valves for general purposes
  • BS3808:1964
    Cast and forged steel flanged, screwed and socket welding wedge gate valves (compact design), sizes 2 in and smaller, for the petroleum industry
  • BS3948:1965
    Cast iron parallel slide valves for general purposes
  • BS3952:1965
    Cast iron butterfly valves for general purposes
  • BS3961:1965
    Cast iron screw down stop valves and stop and check valves for general purposes
  • BS 4062-1:1982
    Valves for hydraulic fluid power systems - Methods for determining pressure differential/flow characteristics
  • BS 4062-2:1990
    Valves for hydraulic fluid power systems - Methods for determining performance
  • BS4090:1966
    Cast iron check valves for general purposes
  • BS4133:1967
    Flanged steel parallel slide valves for general purposes
  • BS4312:1968
    Flanged steel screw down stop valves and check valves for general purposes
  • BS 4460:1969
    Steel ball valves for the petroleum industry
  • BS 5041:1987
    Fire hydrant systems equipment - Specification for landing valves for wet risers
  • BS 5146 P1:1984
    Steel valves for the petrochemical and allied industries
  • BS 5150:1990 - Withdrawn, Superseded
    Specification for cast iron gate valves
  • BS 5151:1982 - Withdrawn, Superseded
    Specification for cast iron gate (parallel slide) valves for general purposes
  • BS 5152:1989 - Withdrawn, Superseded
    Cast iron globe & globe stop and check valves
  • BS 5153:1989 - Withdrawn, Superseded
  • BS 5154:1991
    Specification for copper alloy globe, globe stop and check, check and gate valves
  • BS 5155:1992
    Specification for butterfly valves
  • BS 5156:1990
    Specification for diaphragm valves
  • BS 5157:1989
    Specification for steel gate (parallel slide) valves
  • BS 5158:1989
    Specification for cast iron plug valves
  • BS 5159:1982
    Cast iron and carbon steel ball valves for general purposes
  • BS 5160:1989
    Specification for steel globe valves, globe stop and check valves and lift type check valves
  • BS 5163:1991
    Specification for predominantly key-operated cast iron gate valves for waterworks purposes
  • BS 5351:1990
    Steel ball valves for petroleum, petrochemical and allied industries
  • BS 5352:1990
    Steel wedge gate, globe and check valves 50mm and small
  • BS 5353:1989
    Specification for steel plug valves
  • BS 5417:1976
    Testing of general purpose industrial valves
  • BS 5418:1984
    Specification for marking of general purpose industrial valves
  • BS 5672:1991
    Specification for designation of the direction of rotation and of cylinders and valves in cylinder heads, and definition of right-hand and left-hand in-line engines and locations on engines for reciprocating internal combustion engines
  • BS 5793-4:1987
    Industrial-process control valves - Specification for inspection and routine testing
  • BS 5793-6:1986
    Industrial-process control valves - Specification for mounting details for attachment of positioners to control valve actuators
  • BS 5834-1:1985
    Surface boxes, guards and underground chambers for gas and waterworks purposes - Specification for guards, including foundation units
  • BS 5834-2:1983
    Surface boxes, guards and underground chambers for gas and waterworks purposes - Specification for small surface boxes
  • BS 5834-3:1985
    Surface boxes, guards and underground chambers for gas and waterworks purposes - Specification for large surface boxes
  • BS 5834-4:1989
    Surface boxes, guards and underground chambers for gas and waterworks purposes - Specification for preformed chambers
  • BS 5995:1980
    Methods of test for electrohydraulic servovalves
  • BS 6282-2:1982
    Devices with moving parts for the prevention of contamination of water by backflow - Specification for check valves of nominal size up to and including DN 54
  • BS 6282-3:1982
    Devices with moving parts for the prevention of contamination of water by backflow - Specification for in-line anti-vacuum valves of nominal size up to and including DN 42
  • BS 6282-4:1982
    Devices with moving parts for the prevention of contamination of water by backflow - Specification for combined check and anti-vacuum valves of nominal size up to and including DN 42
  • BS 6283-2:1991
    Safety and control devices for use in hot water systems - Specifications for temperature relief valves for pressures from 1 bar to 10 bar
  • BS 6283-4:1991
    Safety and control devices for use in hot water systems - Specification for drop-tight pressure reducing valves of nominal size up to and including DN 50 for supply pressures up to and including 12 bar
  • BS 6494-4:1989
    Hydraulic fluid power valve mounting surfaces - Specification for clamping dimensions of four-part, size 03 and 05, modular stack valves and directional control valves
  • BS 6675:1986
    Specification for servicing valves (copper alloy) for water services
  • BS 6683:1985
    Guide to installation and use of valves
  • BS 6697:1986
    Methods of test for electrohydraulic proportional control valves
  • BS 6755-2:1987
    Testing of valves - Specification for fire type-testing requirements
  • BS 6759-1:1995
    Safety valves - Part 1. Specification for safety valves for steam and hot water
  • BS 6759-2:1997
    Safety valves - Part 2. Safety valves for compressed air or inert gas
  • BS 6759-3:1995
    Safety valves - Part 3. Specification for safety valves for process fluids
  • BS 6821:1988
    Methods for aerodynamic testing of dampers and valves
  • BS 7296-1:1990
    Cavities for hydraulic fluid power cartridge valves - specification for two-port slip-in valves
  • BS 7350:1990
    Specification for double regulating globe valves and flow measurement devices for heating and chilled water systems
  • BS 7389-1:1990
    Pneumatic fluid power valve mounting surfaces - specification for five-port directional control valves (without electrical motor)
  • BS 7438:1991
    Specification steel and copper alloy waffer check valves, single disk, spring-loaded type
  • BS EN 488:2003
    District heating pipes - Preinsulated bonded pipe systems for directly buried hot water networks - Steel valve assembly for steel service pipes, polyurethane thermal insulation and outer casing of polyethylene
  • BS EN 558-1:1996
    Industrial values face to face and center to face dimensions of metal valves for use in flanged pipe systems. Part 1 PN designated valves
  • BS EN 558-2:1996
    Industrial valves face to face and center to face dimensions of metal valves for use in flanged piping systems. Part 2 class-designated valves
  • BS EN 561:2002
    Gas welding equipment - Quick-action coupling with shut-off valves for welding, cutting and allied processes
  • BS EN 736-1:1995
    Valves - Terminology - Definition of types of valves
  • BS EN 736-2:1997
    Valves - Terminology - Definition of components of valves
  • BS EN 816:1997
    Sanitary tapware - Automatic shut-off valves PN 10
  • BS EN 917:1997
    Plastics piping systems - Thermoplastics valves - Test methods for resistance to internal pressure and leaktightness
  • BS EN 1092-2:1997
    Flanges and their joints - Circular flanges for pipes, valves, fittings and accessories, PN designated - Cast iron flanges
  • BS EN 1112:1997
    Shower outlets for (PN 10) sanitary tapware
  • BS EN 1680:1997
    Plastics piping systems - Valves for polyethylene (PE) piping systems - Test method for leaktightness under and after bending applied to the operating mechanism
  • BS EN 1704:1997
    Plastics piping systems - Thermoplastics valves - Test method for the integrity of a valve after temperature cycling under bending
  • BS EN 1705:1997
    Plastics piping systems - Thermoplastics valves - Test method for the integrity of a valve after an external blow
  • BS EN 12119:1997
    Plastics piping systems - Polyethylene (PE) valves - Test method for resistance to thermal cycling
  • BS EN 14141:2003
    Valves for natural gas transportation in pipelines - Performance requirements and tests
  • BS EN 14189:2003
    Transportable gas cylinders. Inspection and maintenance of cylinder valves at time of periodic inspection of gas cylinders. Partially replaces BS 341-1:1991
  • BS EN 28233:1992
    Thermoplastics valves - Torque - Test method
  • BS EN 28659:1992
    Thermoplastics valves - Fatigue strength - Test method
  • BS EN 60534-1:1989
    Industrial-process control valves - Industrial-process control valves - Control valve terminology and general considerations
  • BS EN 60534-2-1:1999
    Industrial-process control valves - Flow capacity - Flow capacity - Sizing equations for fluid flow under installed conditions
  • BS EN 60534-2-3:1998
    Industrial-process control valves - Flow capacity - Test procedures
  • BS EN 60534-2-5:2003
    Industrial-process control valves - Flow capacity - Sizing equations for fluid flow through multistage control valves with interstage recovery
  • BS EN 60534-3-1:2000
    Industrial-process control valves - Dimensions - Face-to-face dimensions for flanged, two-way, globe-type, straight pattern and centre-to-face dimensions for flanged, two-way, globe-type, angle pattern control valves
  • BS EN 60534-3-2:2001
    Industrial-process control valves - Dimensions - Face-to-face dimensions for rotary control valves except butterfly valves
  • BS EN 60534-3-3:1998
    Industrial-process control valves - Dimensions - End-to-end dimensions for buttweld, two-way, globe-type, straight pattern control valves
  • BS EN 60534-5:2004
    Industrial-process control valves - Marking
  • BS EN 60534-6-1:1998
    Industrial-process control valves - Mounting details for attachment of positioners to control valves - Positioner mounting on linear actuators
  • BS EN 60534-6-2:2001
    Industrial-process control valves - Mounting details for attachment of positioners to control valves - Positioner mounting on rotary actuators
  • BS EN 60534-8-1:2001
    Industrial-process control valves - Noise considerations - Laboratory measurement of noise generated by aerodynamic flow through control valves
  • BS EN 60534-8-2:1991
    Industrial-process control valves - Noise considerations - Laboratory measurement of noise generated by hydrodynamic flow through control valves
  • BS EN 60534-8-3:2000
    Industrial-process control valves - Noise considerations - Control valve aerodynamic noise prediction method
  • BS EN 60534-8-4:1994
    Industrial-process control valves - Noise considerations - Prediction of noise generated by hydrodynamic flow
  • BS EN 60730-2-8:2002
    Specification for automatic electrical controls for household and similar use - Particular requirements - Particular requirements for electrically operated water valves, including mechanical requirements
  • BS EN ISO 5210:1996
    Industrial valves - Multi-turn valve actuator attachments
  • BS ISO 4401:1996
    Hydraulic fluid power - Four-port directional control valves - Mounting surfaces
  • BS ISO 6263:1997
    Hydraulic fluid power - Compensated flow-control valves - Mounting surfaces
Valve Standards
International standards for valves in piping systems.
API - Valve Standards
An overview of the American Petroleum Institute - API - valve standards.
ASME - Valve Standards
An overview of the American Society of Mechanical Engineers - ASME - valve standards.
ASTM - Valve Standards
An overview of ASTM International - American Society for Testing and Materials - valve standards.
BSi - Pipe, Tube and Fittings Standards and Specifications
British standards and specifications for pipe, tube and fittings.
Chinese and International Valve Standards
Chinese valve standards compared with the international ISO, ASTM , ASME, ANSI, MSS, API and JIS standards.
DIN - Valve Standards
An overview of DIN - Deutsches Institut für Normung - valve standards.
ISO Valve Standards
An overview of ISO - International Organization for Standardization - valve standards.
JIS - Valve Standards
Japanese industrial valve standards and specifications from JAS - the Japanese Standards Association.
MSS - Valve Standards
Manufacturers Standardization Society - MSS - of the Valve and Fittings Industry - valve standards.
Pilot Operated Safety Valves in Liquid Systems
Calculate pilot operated relief valves in liquid systems.
SAE Valve Standards
SAE - Society of Automotive Engineers - valve standards.
Valve Type Classifications
Categories of valves.
