ASME - Valve Standards
Common valve standards from American Society of Mechanical Engineers - ASME:
  • ASME A105/105M
    Standard Specification for Carbon Steel Forgings for piping applications
  • ASME A181/181M
    Standard Specification for Carbon Steel Forgings for General purpose piping
  • ASME A182/182M
    Standard Specification for forged or rolled alloy-steel pipe flanges, forged fittings and valves and parts for high-temperature service
  • ASME A727/727M
    Standard specification for carbon steel forgings for piping components with inherent notch toughness
  • ASME A961
    Standard Specification for Common Requirements for Steel Flanges, Forged Fittings, valves, and Parts for Piping Applications
  • ASME B16.10
    Face to Face and End-to-End Dimensions of Valves
  • ASME B16.34
    Valves - Flanged, Threaded, and Welding End
  • ASME B462
    Standard Specification for Forged or Rolled UNS N08020, UNS N08024, UNS N08026, UNS N08367, and UNS R20033 Alloy Pipe Flanges, Forged Fittings, and Valves and Parts for Corrosive High-Temperature Service
  • ASME B834
    Standard Specification for Pressure Consolidated Powder Metallurgy Iron-Nickel- Chromium-Molybdenum (UNS N08367) and Nickel- Chromium Molybdenum Columbium (Nb) (UNS N06625) Alloy Pipe Flanges, Fittings, Valves, and Parts
  • ASME D5500
    Standard Test Method for Vehicle Evaluation of Unleaded Automotive Spark-ignition Engine Fuel for Intake Valve Deposit Formation
  • ASME F885
    Standard Specification for Envelope Dimensions for Bronze Globe Valves NPS 1/4 to 2 El-1996 R(1996)
  • ASME F992
    Standard Specification for Valve Label Plates El-1997 R(1997)
  • ASME F993
    Standard Specification for Valve Locking Devices El-1997 R(1997)
  • ASME F1020
    Standard Specification for Line-Blind Valves for marine Applications El-1996 RI'1996)
  • ASME F1098
    Standard Specification for Envelope Dimensions for Butterfly Valves - NPS 2 to 24 EI-1993 R(1993)
  • ASME F1271
    Standard Specification for Spill Valves for Use in Marine Tank Liquid Overpressure Protections Applications EI-1995 R (1995)
  • ASME F1370
    Standard Specification for Pressure Reducing valves for Water Systems, Shipboard
  • ASME F1508
    Standard Specification for Angle Style, Pressure Relief Valves for Steam, Gas, and Liquid Services
  • ASME F1565
    Standard Specification for Pressure-Reducing Valves for Steam Service
  • ASME F1792
    Standard Specification for Special Requirements for Valves Used in Gaseous Oxygen Service
  • ASME F1793
    Standard Specification for Automatic Shut-Off Valves (Also Known as Excess Flow Valves, EFV) for Air or Nitrogen Service
  • ASME F1794
    Standard Specification for Hand operated, Globe-Style Valves for Gas (Except Oxygen Gas), and Hydraulic Systems
  • ASME F1795
    Standard specification for Pressure-Reducing Valves for Air or Nitrogen Systems
  • ASME A230
    Standard specification for steel wire oil - tempered carbon valve spring quality
  • ASME A232
    Standard specification for chromium - vanadium alloy steel valve spring quality
  • ASME A350
    Standard specification for forged or rolled carbon and alloy steel flanges forged fittings and valves and parts for low - temperature service
  • ASME A338
    Standard specification for ultrasonic examination of heavy steel forgings
  • ASME A694
    Standard specification for forgings carbon and alloy steel for pipe flanges fittings valves and parts for high - pressure transmission service
  • ASME A404
    Standards specification for forged or rolled alloy - steel pipe flanges forged fittings and valves and parts specially heat treated for high temperature service
  • ASME A522
    Forged or rolled 8% and 9% nickel alloy steel flanges fittings valves and parts for low - temperature service
Valve Standards
International standards for valves in piping systems.
API - Valve Standards
An overview of the American Petroleum Institute - API - valve standards.
ASME - American Society of Mechanical Engineers
ASME is one of the leading organizations in the world developing codes and standards.
ASME - Performance Test Codes
The ASME Performance Test Codes provide standard directions and rules for conducting and reporting tests.
An overview of the American Society of Mechanical Engineers - ASME - valve standards.
ASTM - Valve Standards
An overview of ASTM International - American Society for Testing and Materials - valve standards.
BSi - British Standard Valves
An overview of BSi - British Standard institute valve standards.
Chinese and International Valve Standards
Chinese valve standards compared with the international ISO, ASTM , ASME, ANSI, MSS, API and JIS standards.
DIN - Valve Standards
An overview of DIN - Deutsches Institut für Normung - valve standards.
ISO Valve Standards
An overview of ISO - International Organization for Standardization - valve standards.
JIS - Valve Standards
Japanese industrial valve standards and specifications from JAS - the Japanese Standards Association.
MSS - Valve Standards
Manufacturers Standardization Society - MSS - of the Valve and Fittings Industry - valve standards.
UNS - Unified Numbering System
The Unified Numbering System - UNS - used for metals and alloys.
Valve Selection Guide
Applications guide for selecting valves.
Valves - Specific Services
Valves - Typical Operating Temperatures
Operating temperatures for typical categories of valves - ball valves, butterfly valves and more.
