Valves - Typical Operating Temperatures
Typical operating temperatures for some common types of valves:
Valve TypeMinimum
Temperature
Maximum
Temperature
oCoFoCoF
Ball -55 -65 300 575
Butterfly -30 -20 538 1000
Butterfly Neck -18 0 260 500
Gate -272 -455 675 1250
Globe -272 -455 540 1000
Plug Lubricated -40 -40 315 600
Plug non lubricated -75 -100 220 425
Swing Check -18 0 540 1200
Swing Check Y-type -18 0 540 1200
Lift Check -18 0 540 1200
Tilting disc -260 -450 590 1100
Diaphragm -50 -60 230 450
Y Oblique -272 -455 540 1000
Slide -18 0 650 1200
Pinch -75 -100 260 300
Needle -78 -100 260 500
Control Valves
Control Valve terminology, bodies, trim, flow characteristics, Cv and Kv sizing, noise, actuators and positioners
Piping Systems
API - Valve Standards
An overview of the American Petroleum Institute - API - valve standards.
API 6D Valves - Pressure Ratings vs. Temperature
Temperature and pressure ratings for valves according API 6D.
ASME - Valve Standards
An overview of the American Society of Mechanical Engineers - ASME - valve standards.
ASTM - Valve Standards
An overview of ASTM International - American Society for Testing and Materials - valve standards.
ASTM A216 Valves - Pressure Ratings vs. Temperature
Pressure and temperature ratings for cast carbon steel valves.
Cavitation
Cavitation occurs in fluid flow systems where the local static pressures are below the fluids vapor pressure.
Control Valves - Cavitation
Control valves and cavitation, application ratio and multi stage control valves.
Control Valves - Flow Characteristics
Flow capacities vs. stem opening.
Control Valves - Leakage Classification
Seat leakage classification through control valves.
ISO Valve Standards
An overview of ISO - International Organization for Standardization - valve standards.
Valve Abbreviations
US valve abbreviations commonly used in drawings and documentation.
Valve Authority
The valve authority expresses the ratio between pressure drop across the control valve compared to total pressure drop across the whole system.
Valve Type Classifications
Categories of valves.
Valves Types - Operating Size Ranges
Types of valves and their typical operating sizes.
