Valves Types - Operating Size Ranges
Valves and typical operating sizes:
Type of Valve | Minimum Size | Maximum Size | ||
mm | inches | mm | inches | |
Ball | 6 | 1220 | 48 | |
Butterfly | 50 | 2 | 1830 | 72 |
Butterfly Neck | 25 | 1 | 1830 | 72 |
Gate | 3 | 1/8 | 1220 | 48 |
Globe | 3 | 1/8 | 760 | 30 |
Plug Lubricated | 6 | 760 | 30 | |
Plug non lubricated | 6 | 406 | 16 | |
Swing Check | 6 | 610 | 24 | |
Swing Check Y-type | 6 | 150 | 6 | |
Lift Check | 6 | 250 | 10 | |
Tilting disc | 50 | 2 | 760 | 30 |
Diaphragm | 3 | 1/8 | 610 | 24 |
Y Oblique | 3 | 1/8 | 760 | 30 |
Slide | 50 | 2 | 1900 | 75 |
Pinch | 25 | 1 | 305 | 12 |
Needle | 3 | 1/8 | 25 | 1 |
• Control Valves
Control Valve terminology, bodies, trim, flow characteristics, Cv and Kv sizing, noise, actuators and positioners
• Piping Systems
• Valve Standards
International standards for valves in piping systems.
API 6D Valves - Pressure Ratings vs. Temperature
Temperature and pressure ratings for valves according API 6D.
ASTM A216 Valves - Pressure Ratings vs. Temperature
Pressure and temperature ratings for cast carbon steel valves.
Control Valves - Cavitation
Control valves and cavitation, application ratio and multi stage control valves.
Control Valves - Leakage Classification
Seat leakage classification through control valves.
Heating Systems - Safety Valves Size vs. Boiler Power
Safety Valves in Gas and Vapor Systems
Calculating relief valves in gas and vapor systems.
Valve Authority
The valve authority expresses the ratio between pressure drop across the control valve compared to total pressure drop across the whole system.
Valve Type Classifications
Categories of valves.
Valves - Typical Operating Temperatures
Operating temperatures for typical categories of valves - ball valves, butterfly valves and more.
Water Control Valves - Flow Factor Kv Diagram
