Control Valves in Series
The equivalent flow coefficient Kv or Cv for two control valves installed in series can be calculated as
1 / (Kvt)2 = 1 / (Kv1)2 + 1 / (Kv2)2 (1)
Kvt = resulting Kv
Kv1 = Kv valve 1
Kv2 = Kv valve 2
Control Valves in Parallel
The equivalent Kv or Cv for two control valves installed in parallel can be calculated as
Kvt = Kv1 + Kv2 (2)
• Control Valve Sizing
Ball Valves - Flow Coefficients Cv
Flow coefficients - Cv - for typical ball valves - reduced and full bore.
Butterfly Valves - Flow Coefficients Cv
Typical flow coefficients - Cv - for butterfly valves.
Control Valves for Water Flow – Kv Sizing & Pressure Drop Calculations
Control valve sizing and pressure drop calculations for water flow applications. Different valve types, Kv flow coefficients, and how to select the right valves.
Flow Coefficient Cv vs. Flow Factor Kv
Comparing flow coefficients Cv to flow factors Kv.
Gases - Control Valve Calculator
An online control valve - Cv - calculator for gases.
Liquid, Steam and Gas - Flow Factor Kv
Calculate flow factor Kv for liquids, steam and gases - metric units.
Steam Control Valves - Calculate Flow Factor Kv
Designing steam control valves and their Kv values.
Straight Through Diaphragm Valves - Flow Coefficients
Flow coefficients - Cv - and flow factors - Kv - for straight through diaphragm valves.
Valves - Typical Operating Temperatures
Operating temperatures for typical categories of valves - ball valves, butterfly valves and more.
Water Control Valves - Flow Factor Kv Diagram
Water Control Valves - Flow Coefficient Cv Diagram
Sizing of water control valves - Imperial units.
Weir Diaphragm Valves - Flow Coefficients and Flow Factors
Typical flow coefficients - Cv - and flow factors - Kv - for weir diaphragm valves.
