Butterfly Valves - Flow Coefficients Cv
The table below can be used to indicate butterfly valves and their flow coefficients at different open (or closed) positions. Manufacturers data should always be checked before actual use.
| Valve Size | Flow Coefficient - Cv | ||||||
| Openness (disc angle) | Maximum flow velocity (ft/sec) | ||||||
| inches | mm | 90 deg (wide open) | 70 deg | 50 deg | 30 deg | ANSI 150 | ANSI 300 |
| 2 | 50 | 85 | 65 | 35 | 15 | 90 | 90 |
| 2 1/2 | 65 | 160 | 120 | 65 | 29 | 80 | 90 |
| 3 | 80 | 260 | 195 | 104 | 47 | 80 | 80 |
| 4 | 100 | 475 | 356 | 190 | 86 | 80 | 80 |
| 5 | 125 | 770 | 577 | 308 | 139 | 80 | 80 |
| 6 | 150 | 1125 | 844 | 450 | 203 | 75 | 80 |
| 8 | 200 | 2110 | 1583 | 844 | 380 | 70 | 75 |
| 10 | 250 | 3350 | 2513 | 1340 | 603 | 60 | 70 |
| 12 | 300 | 4800 | 3600 | 1920 | 864 | 50 | 60 |
| 14 | 350 | 6900 | 5175 | 2760 | 1224 | 50 | |
| 16 | 400 | 9000 | 6750 | 3600 | 1620 | 50 | |
| 18 | 450 | 11800 | 8850 | 4720 | 2124 | 50 | |
| 20 | 500 | 14300 | 10725 | 5720 | 2574 | 50 | |
- 1 ft/s = 0.3048 m/s
• Control Valve Sizing
• Piping Systems
Ball Valves - Flow Coefficients Cv
Flow coefficients - Cv - for typical ball valves - reduced and full bore.
Control Valves for Water Flow – Kv Sizing & Pressure Drop Calculations
Control valve sizing and pressure drop calculations for water flow applications. Different valve types, Kv flow coefficients, and how to select the right valves.
Flow Coefficient Cv vs. Flow Factor Kv
Comparing flow coefficients Cv to flow factors Kv.
Liquid, Steam and Gas - Flow Factor Kv
Calculate flow factor Kv for liquids, steam and gases - metric units.
Straight Through Diaphragm Valves - Flow Coefficients
Flow coefficients - Cv - and flow factors - Kv - for straight through diaphragm valves.
Water Control Valves - Flow Coefficient Cv Diagram
Sizing of water control valves - Imperial units.
Weir Diaphragm Valves - Flow Coefficients and Flow Factors
Typical flow coefficients - Cv - and flow factors - Kv - for weir diaphragm valves.
