= 1.7
pd > pu / 2:
Kv = 0.032 m (vd / (pu - pd))1/2 (2)
m = mass flow (kg/h)
pu = upstream pressure (bar abs)
pd = downstream pressure (bar abs)
vd = specific weight of downstream steam and actual temperature (m3/kg)
pd < pu / 2:
Kv = 0.032 m (2 vd2 / pu )1/2 (2b)
vd2 = specific volume for steam with pressure pu / 2 and actual temperature (m3/kg)
pd > pu / 2:
Kv = 0.0019 q (ρg Tu / (pd (pu - pd)))1/2 (3)
q = volume flow of gas at 0oC and 1013 mbar (m3/h)
ρg = density of gas at 0oC and 1013 mbar (kg/m3)
Tu = upstream temperature (K)
pd < pu / 2:
Kv = 0.0039 q (ρg Tu)1/2 / pu (3b)
Control Valve terminology, bodies, trim, flow characteristics, Cv and Kv sizing, noise, actuators and positioners
Typical flow coefficients - Cv - for butterfly valves.
Comparing flow coefficients Cv to flow factors Kv.
The valve authority expresses the ratio between pressure drop across the control valve compared to total pressure drop across the whole system.
Designing water process control valves and their Kv values.
