Straight Through Diaphragm Valves - Flow Coefficients
Typical flow coefficients - Cv - and flow factors - Kv - for diaphragm straight through flanged cast iron valves of "Saunders" type:
Valve Size | Unlined | Rubber Lined | Glass/Plastic Lined | ||||
DN | Inches | Cv | Kv | Cv | Kv | Cv | Kv |
15 | 1/2 | 9 | 7 | 9 | 8 | ||
25 | 1 | 38 | 33 | 31 | 26 | 39 | 34 |
32 | 1 1/4 | 56 | 48 | 46 | 39 | 58 | 50 |
40 | 1 1/2 | 75 | 65 | 66 | 57 | 79 | 68 |
50 | 2 | 128 | 110 | 107 | 92 | 138 | 119 |
65 | 2 1/2 | 238 | 205 | 195 | 168 | 254 | 219 |
80 | 3 | 330 | 284 | 264 | 228 | 342 | 295 |
100 | 4 | 588 | 507 | 480 | 414 | 618 | 533 |
125 | 5 | 924 | 797 | 720 | 621 | 960 | 828 |
150 | 6 | 1 680 | 1 448 | 1 260 | 1 086 | 1 800 | 1 552 |
200 | 8 | 2 580 | 2 224 | 2 196 | 1 893 | 2 724 | 2 348 |
250 | 10 | 4 020 | 3 466 | 3 420 | 2 948 | 4 296 | 3 703 |
300 | 12 | 6 060 | 5 224 | 4 884 | 4 210 | ||
350 | 14 | 10 300 | 8 879 | 9 950 | 8 578 |
The opening and closing characteristic of the valves are close to positive linear:
- closing a valve to 80% - reduces the flow coefficient to approximately 85%
- closing a valve to 50% - reduces the flow coefficient to approximately 60%
This close to linear characteristic make the valves suited for adjustment and balancing operations. In addition the lined versions are able to resist wear and tear and rough environments and processes.
• Control Valves
Control Valve terminology, bodies, trim, flow characteristics, Cv and Kv sizing, noise, actuators and positioners
• Control Valves and Equipment
• Piping Systems
Ball Valves - Flow Coefficients Cv
Flow coefficients - Cv - for typical ball valves - reduced and full bore.
Butterfly Valves - Flow Coefficients Cv
Typical flow coefficients - Cv - for butterfly valves.
Control Valves - Cavitation
Control valves and cavitation, application ratio and multi stage control valves.
Control Valves - Flow Characteristics
Flow capacities vs. stem opening.
Control Valves - Sizing and Selection
Sizing control valves to match process requirements.
Control Valves for Liquids - Sizing Calculator
Online control valve - Cv - calculator for liquids flow.
Diaphragm Valves - Diaphragm Materials
Common diaphragm materials and their main properties when used in diaphragm valves.
Flow Coefficient Cv vs. Flow Factor Kv
Comparing flow coefficients Cv to flow factors Kv.
Valve Authority
The valve authority expresses the ratio between pressure drop across the control valve compared to total pressure drop across the whole system.
Valve Type Classifications
Categories of valves.
Valves - Specific Services
Water Control Valves - Flow Factor Kv Diagram
Water Control Valves - Flow Coefficient Cv Diagram
Sizing of water control valves - Imperial units.
Water Control Valves - Kv Calculation
Designing water process control valves and their Kv values.
Weir Diaphragm Valves - Flow Coefficients and Flow Factors
Typical flow coefficients - Cv - and flow factors - Kv - for weir diaphragm valves.
