Control Valves for Liquids - Sizing Calculator
Online control valve - Cv - calculator for liquids flow.
http://www.engineeringtoolbox.com/flow-coefficients-d_277.html
Control Valves
Control Valve terminology, bodies, trim, flow characteristics, Cv and Kv sizing, noise, actuators and positioners
Straight Through Diaphragm Valves - Flow Coefficients
Flow coefficients - Cv - and flow factors - Kv - for straight through diaphragm valves.
