Ball Valves - Flow Coefficients Cv
A conventional ball valve is normally not used as a throttling valve since a partial flow will create high velocity flow tear at the ball and the seal.
Full Bore Valves
Typical flow coefficients - Cv - for full bore valves:
Valve Size
inches1/23/411
1/2
22
1/2
34681012141618
mm12192537.55062.575100150200250300350400450
Flow Coefficient
C
v
26 50 94 260 480 750 1300 2300 5400 10000 16000 24000 31400 43000 57000
Reduced Bore Valves
Typical flow coefficients - Cv - for reduced bore valves:
Valve Size
inches3468101214161820
mm75100150200250300350400450500
Flow Coefficient
C
v
420 770 1800 2500 4500 8000 12000 14000 18000 22000
These values are suitable for estimates only. Since the bore in valves varies the valve manufacturer should always be consulted for the actual Cv for the valve selected.
Control Valves
Control Valve terminology, bodies, trim, flow characteristics, Cv and Kv sizing, noise, actuators and positioners
Piping Systems
Butterfly Valves - Flow Coefficients Cv
Typical flow coefficients - Cv - for butterfly valves.
Control Valves - Cavitation
Control valves and cavitation, application ratio and multi stage control valves.
Control Valves - Flow Characteristics
Flow capacities vs. stem opening.
Control Valves - Sizing and Selection
Sizing control valves to match process requirements.
Flow Coefficient Cv vs. Flow Factor Kv
Comparing flow coefficients Cv to flow factors Kv.
Steam Control Valves - Calculate Flow Factor Kv
Designing steam control valves and their Kv values.
Straight Through Diaphragm Valves - Flow Coefficients
Flow coefficients - Cv - and flow factors - Kv - for straight through diaphragm valves.
Valve Authority
The valve authority expresses the ratio between pressure drop across the control valve compared to total pressure drop across the whole system.
Water Control Valves - Flow Factor Kv Diagram
Water Control Valves - Flow Coefficient Cv Diagram
Sizing of water control valves - Imperial units.
Water Control Valves - Kv Calculation
Designing water process control valves and their Kv values.
