Gases - Control Valve Calculator
An online Cv calculator for gases. The Full Scale Flow Rate are entered in Standard Cubic Feet per Hour (SCFH).
http://www.engineeringtoolbox.com/flow-coefficients-d_277.html
Control Valves
Control Valve terminology, bodies, trim, flow characteristics, Cv and Kv sizing, noise, actuators and positioners
Gases and Compressed Air
Process Control
Instrumentation and process control systems - design and documentation.
Process Controllers - P, PI & PID
Steam Control Valves - Calculate Flow Factor Kv
Designing steam control valves and their Kv values.
