Valve Selection Guide
The suitability of a valve for a particular application is decided by the materials used in relation to the conveyed fluid as well as its mechanical design. The table below can be used as a valve selection guide.
Conveyed FluidNature of FluidValve FunctionType of Disc
Liquid Neutral
(Water, Oil, etc)
On/Off Gate
Rotary ball
Plug
Diaphragm
Butterfly
Plug gate
Control valve, modulating Globe
Butterfly
Plug gate
Diaphragm
Needle
Corrosive
(Acid, alkaline etc.)
On/Off Gate
Plug gate
Rotary ball
Plug
Diaphragm
Butterfly
Diaphragm
Butterfly
Plug gate
Hygienic
(Food, beverages, drugs etc)
On/Off Butterfly
Diaphragm
Control valve, modulating Butterfly
Diaphragm
Squeeze
Pinch
Slurry On/Off Rotary ball
Butterfly
Diaphragm
Plug
Pinch
Squeeze
Diaphragm
Squeeze
Pinch
Gate
Fibrous Suspensions On/Off,
Gate
Diaphragm
Squeeze
Pinch
Gas Neutral
(Air, Steam etc)
On/Off Gate
Globe
Rotary ball
Plug
Diaphragm
Needle
Butterfly
Diaphragm
Gate
Corrosive
(Acid vapors, chlorine etc.)
On/Off Butterfly
Rotary ball
Diaphragm
Plug
Globe
Needle
Diaphragm
Vacuum On/Off Gate
Globe
Rotary ball
Butterfly
Solids Abrasive Powder
(Silica, etc)
On/Off,
Pinch
Squeeze
Spiral sock
Lubricating powder (graphite, talcum, etc On/Off,
Pinch
Gate
Spiral sock
Squeeze
Control Valves
Control Valve terminology, bodies, trim, flow characteristics, Cv and Kv sizing, noise, actuators and positioners
Control Valves and Equipment
Piping Systems
Valve Standards
International standards for valves in piping systems.
ASME - Valve Standards
An overview of the American Society of Mechanical Engineers - ASME - valve standards.
ASTM - Valve Standards
An overview of ASTM International - American Society for Testing and Materials - valve standards.
Control Valves - Flow Characteristics
Flow capacities vs. stem opening.
Control Valves - Leakage Classification
Seat leakage classification through control valves.
Diaphragm Valves - Diaphragm Materials
Common diaphragm materials and their main properties when used in diaphragm valves.
ISO Valve Standards
An overview of ISO - International Organization for Standardization - valve standards.
Safety Valve Standards
The most common used safety valve standards in Germany, UK, USA, France, Japan, Australia and Europe.
Slurry Transports - Minimum Flow Velocities
Flow velocities in slurry transport systems to avoid settling of solids.
Steam Control Valves - Calculate Flow Factor Kv
Designing steam control valves and their Kv values.
Valve Abbreviations
US valve abbreviations commonly used in drawings and documentation.
Valve Authority
The valve authority expresses the ratio between pressure drop across the control valve compared to total pressure drop across the whole system.
Valve Type Classifications
Categories of valves.
Weir Diaphragm Valves - Flow Coefficients and Flow Factors
Typical flow coefficients - Cv - and flow factors - Kv - for weir diaphragm valves.
