(e.g. 150 g weight falling from 15 cm height)
In order to comply with the stringent requirements for CE Marking machine makers today fits their machines with parts certified according EU (European Union) and international standards.
An electrical socket rated IP22 is protected against
Documentation of process control systems - Block Flow Diagrams (BFD), Process Flow Diagrams (PFD), Piping and Instrumentation Diagrams (P&ID) and more
Electrical units, amps and electrical wiring, wire gauge and AWG, electrical formulas and motors.
Instrumentation and process control systems - design and documentation.
Verifies that a product is designed to the appropriate standards according the European Machine Directive.
NEMA - electrical motor efficiency ratings.
European hazardous area classification with zones, protection types, temperature codes and codes.
North American hazardous locations classification with classes, divisions and groups
Hazardous areas protection techniques - explosion proof, flameproof and intrinsically safe.
Dust-ignition proof, explosion proof, instrinsically safe and nonincendive protection of hazardous areas.
The ISA standards and symbols are important for the P&IDs and documents describing the process control system.
NEMA enclosure classifications versus IEC enclosure classifications.
NEMA enclosure standard for electrical motors.
Maximum fire sprinkler protected area vs. classification and construction.
