NEMA Enclosure Standards for Electric Motors
The enclosures of electrical motors are standardized by NEMA (National Electrical Manufacturers Association) as:
Drip-Proof
Ventilation openings in shield and/or frame prevents drops of liquid from falling into motor within up to 15 degree angle from vertical.
Designed for reasonably dry, clean, and well ventilated (usually indoors) areas. Outdoors installation require the motor to be protected with a cover that does not restrict the flow of air to the motor.
Totally Enclosed Air Over (TEAO)
Dust-tight fan and blower motors for shaft mounted fans or belt driven fans. The motors mounted within the airflow of the fan.
Totally Enclosed Non-Ventilated (TENV)
No ventilation openings, enclosed to prevent free exchange of air (not airtight). No external cooling fan, relies on convection cooling.
Suitable where the motor is exposed to dirt or dampness. Not suited in very moist humid or hazardous (explosive) air.
Totally Enclosed Fan Cooled (TEFC)
Same as TENV with an external fan as an integral part of the motor. The fan provides cooling by blowing air on the outside of the motor.
Totally Enclosed, Hostile and Severe Environment
Designed for use in extreme conditions - moist and/or chemical environments. Not for hazardous locations.
Totally Enclosed Blower Cooled
Same as TEFC with external fan on a power supply independent of the inverter output. Full cooling even at lower motor speeds.
Explosion-Proof Motors
The motor ambient temperature shall not exceed +40oC. Motors are approved for the classes:
CLASS I (Gases, Vapors)
  • Group A - Acetylene
  • Group B - Butadiene, ethylene oxide, hydrogen, propylene oxide
  • Group C - Acetaldehyde, cyclopropane, diethel ether, ethylene, isoprene
  • Group D - Acetone, acrylonitrite, ammonia, benzene, butane, ethylene dichloride, gasoline, hexane, methane, methanol, naphtha, propane, propylene, styrene, toluene, vinyl acetate, vinyl chloride, xylem
CLASS II (Combustible Dusts)
  • Group E - Aluminum, magnesium and other metal dusts with similar characteristics.
  • Group F - Carbon black, coke or coal dust
  • Group G - Flour, starch or grain dust
CLASS III (Fibers and flyings)
Electrical
Electrical units, amps and electrical wiring, wire gauge and AWG, electrical formulas and motors.
Dust Explosions - Substances, Critical Temperatures and Concentrations
Critical temperatures and concentration parameters for substances like coal, zinc, uranium and more.
Electrical Enclosure Types by NEMA
Description of NEMA electrical enclosures types.
Electrical Motors - Frame Dimensions
Electrical motors NEMA frame dimensions.
Electrical Motors - NEMA Frame Assignments
NEMA frame assignments.
Electrical Motors Efficiency Ratings
NEMA - electrical motor efficiency ratings.
Hazardous Areas - North America Classification
North American hazardous locations classification with classes, divisions and groups
IP - Ingress Protection Ratings
IP - Ingress Protection rating is used to specify the environmental protection - or electrical enclosure - of electrical equipment.
NEMA - National Electrical Manufacturers Association
National Electrical Manufacturers Association.
NEMA Insulation Classes
Electrical insulation systems rated by standard NEMA classifications to maximize allowable operating temperatures.
