Electrical Motors Efficiency Ratings
The efficiency of an electrical motor is the ratio mechanical power output to the electric power input.
NEMA has established the efficiency index:
NEMA Letter IndexNominal EfficiencyMinimum Efficiency
A   95.0
B 95.0 94.1
C 94.1 93.0
D 93.0 91.7
E 91.7 90.2
F 90.2 88.5
G 88.5 86.5
H 86.5 84.0
K 84.0 81.5
L 81.5 78.5
M 78.5 75.5
N 75.5 72.0
P 72.0 68.0
R 68.0 64.0
S 64.0 59.5
T 59.5 55.0
U 55.0 50.5
V 50.5 46.0
W   46.0
Electrical
Electrical units, amps and electrical wiring, wire gauge and AWG, electrical formulas and motors.
Electric Motors - IEC and NEMA Standard Torques
IEC and NEMA torque classifications of electrical motors.
Electrical Enclosure Types by NEMA
Description of NEMA electrical enclosures types.
Electrical Motors - Frame Dimensions
Electrical motors NEMA frame dimensions.
Electrical Motors - Locked Rotor Design Code Letters
NEMA locked rotor indicating code letters for electrical motors.
Electrical Motors - NEMA Frame Assignments
NEMA frame assignments.
IP - Ingress Protection Ratings
IP - Ingress Protection rating is used to specify the environmental protection - or electrical enclosure - of electrical equipment.
NEMA - National Electrical Manufacturers Association
National Electrical Manufacturers Association.
NEMA A, B, C and D Electrical Motor Design
NEMA has established the four different designs A, B, C and D for electrical induction motors.
NEMA Enclosure Standards for Electric Motors
NEMA enclosure standard for electrical motors.
Nema Starters
Nema sized contactors or starters.
