Electrical units, amps and electrical wiring, wire gauge and AWG, electrical formulas and motors.
IEC and NEMA torque classifications of electrical motors.
Slip is the difference between an electrical induction motor's synchronous and asynchronous speed.
Full load operating torque vs. break down, pull up and locked rotor torque.
Electrical motors NEMA frame dimensions.
NEMA frame assignments.
NEMA - electrical motor efficiency ratings.
National Electrical Manufacturers Association.
Full load amps, wire and conduit sizes for three phase electrical motors.
