Hazardous Areas - European Classification Standard
In Europe and most of the world outside North America hazardous areas are classified with the Zone system - where
  • Zones - defines the general nature (or properties) of the hazardous material - if its gas or dust, and the probability of the hazardous material in the surrounding atmosphere
  • Groups - defines the type of the hazardous material and (partly) the location of the surrounding atmosphere
The Zone area classification system is based on the International Electrotechnical Commission IEC 60079 Explosive atmospheres.
In North America hazardous areas are classified by the Class/Division system - or by a Zone system adapted to the IEC standards.
Zones
A Zone defines the general nature - if it is a gas or dust - and the probability of hazardous material being present in an ignitable concentration in the surrounding atmosphere. The Zone system has three levels of hazard for gas or dust.
Gases, Vapors and Mists
IEC 60079-10.1 Classification of areas - Explosive gas atmospheres
Hazardous Areas - European Classification Standard - Gases, Vapors and Mists
ZoneNature and Probability of Hazard Material
Zone 0 Ignitable concentrations of flammable gases or vapors which are present continuously or for long periods of time.
Zone 1 Ignitable concentrations of flammable gases or vapors which are likely to occur under normal operating conditions.
Zone 2 Ignitable concentrations of flammable gases or vapors which are not likely to occur under normal operating conditions and do so only for a short period of time.
Dusts
IEC 60079-10.2 Classification of areas - Combustible dust atmospheres
Hazardous Areas - European Classification Standard - Dusts
Zone 20 An area where combustible dusts or ignitable fibers and flyings are present continuously or for long periods of time.
Zone 21 An area where combustible dusts or ignitable fibers and flyings are likely to occur under normal operating conditions.
Zone 22 An area where combustible dusts or ignitable fibers and flyings are not likely to occur under normal operating conditions and do so only for a short period of time.
Zones compares to classes and divisions in the North American Class/Division system.
Group
Group define the type of hazardous material and (partly) the location of the surrounding atmosphere. Group is divided in three groups where group I is reserved for mining locations.
Hazardous Areas - European Classification Standard - Groups
GroupType of Hazardous Material and Location of Atmosphere
Group I Mines
susceptible to firedamp (flammable mixture of gases naturally occurring in a mine).
Group II Explosive gas
atmosphere other than mines susceptible to firedamp. Group II equipment is subdivided into three subgroups.
A Atmospheres containing propane, acetone, benzene, butane, methane, petrol, hexane, paint solvents or gases and vapors of equivalent hazard.
B Atmospheres containing ethylene, propylene oxide, ethylene oxide, butadiene, cyclopropane, ethyl ether, or gases and vapors of equivalent hazard.
C Atmospheres containing acetylene, hydrogen, carbon disulphide or gases and vapors of equivalent hazard.
Group III Explosive dust
atmosphere. Group III equipment is subdivided into three subgroups.
A Atmospheres containing combustible flyings.
B Atmospheres containing non-conductive dust.
C Atmospheres containing conductive dust.
Example - Hazardous Area Classification
A room with a propane gas installation will typically be classified as
  • Zone 2, Group IIA
A petrol pump will typically be classified as
  • Zone 1, Group IIA
Miscellaneous
Process Control Systems
Instrumentation, design and documentation of process control systems.
Risk, Reliability and Safety
CE Marking
Verifies that a product is designed to the appropriate standards according the European Machine Directive.
Chemicals Hazard Rating System
The National Fire Protection Association (NFPA) hazard system for chemical materials.
Classification of Gases
Oxidizers vs. inert vs. flammable gases.
Dust Explosions - Substances, Critical Temperatures and Concentrations
Critical temperatures and concentration parameters for substances like coal, zinc, uranium and more.
Factors of Safety - FOS
Factors of Safety - FOS - are important in engineering designs.
Firefighting Water - Required Volume Flow
Required water for firefighting.
Fluids - Identity Colors
Identifying colors used for fluid piping systems.
Gases - Dangerous Concentration Levels
Dangerous vs. tolerable concentration levels for some industrial gases.
Hazardous Areas - North America Classification
North American hazardous locations classification with classes, divisions and groups
Hazardous Areas - Protection Techniques according European IECEx
Hazardous areas protection techniques - explosion proof, flameproof and intrinsically safe.
Hazardous Areas Protection Techniques for North America
Dust-ignition proof, explosion proof, instrinsically safe and nonincendive protection of hazardous areas.
Hydrocarbons - Autoignition Temperatures and Flash Points
Autoignition temperatures and flash points (°C and °F) of different types of hydrocarbons with varying carbon numbers up to C12.
IP - Ingress Protection Ratings
IP - Ingress Protection rating is used to specify the environmental protection - or electrical enclosure - of electrical equipment.
Water Sprinkler Protected Areas and Hazard Classification
Maximum fire sprinkler protected area vs. classification and construction.
