Water Sprinkler Protected Areas and Hazard Classification
Maximum protection area per sprinkler:
Water Sprinkler - Protected Areas vs. Hazard Classification
Hazard ClassificationCeiling and Sidewall ConstructionMaximum Protected Area
(ft2)(m2)
Light Standard pendent and upright sprinklers Unobstructed 225 20.9
Non combustible obstructed 225 20.9
Combustible obstructed 168 15.6
Standard sidewall sprinklers Combustible finish 120 11.1
Noncombustible finish 196 18.2
Ordinary Standard pendent and upright sprinklers All 130 12.1
Standard sidewall sprinklers Combustible finish 80 7.4
Noncombustible or limited combustible finish 100 9.3
Extra Standard pendent and upright sprinklers All 100 9.3
High-piled Standard pendent and upright sprinklers All 100 9.3
Miscellaneous
Risk, Reliability and Safety
Area Units Converter
Convert between units of area.
Chemicals Hazard Rating System
The National Fire Protection Association (NFPA) hazard system for chemical materials.
Chimney's Explosion Doors
Recommended size of explosion doors or draught stabilizers in oil fired installations.
Dust Explosions - Substances, Critical Temperatures and Concentrations
Critical temperatures and concentration parameters for substances like coal, zinc, uranium and more.
Electrical Enclosure Types by NEMA
Description of NEMA electrical enclosures types.
Fire-Stop Ratings
F-rated, T-rated and L-rated fire-stop systems.
Hazard vs. Flash Points
The flash point of a chemical indicates how easy it may ignite and burn.
Hazardous Areas - European Classification Standard
European hazardous area classification with zones, protection types, temperature codes and codes.
Hazardous Areas - North America Classification
North American hazardous locations classification with classes, divisions and groups
Hazardous Areas - Protection Techniques according European IECEx
Hazardous areas protection techniques - explosion proof, flameproof and intrinsically safe.
Hazardous Areas Protection Techniques for North America
Dust-ignition proof, explosion proof, instrinsically safe and nonincendive protection of hazardous areas.
IP - Ingress Protection Ratings
IP - Ingress Protection rating is used to specify the environmental protection - or electrical enclosure - of electrical equipment.
NFPA - National Fire Protection Association
The U.S. authority on fire, electrical and building safety.
