Fluids - Identity Colors
Identifying colors used for fluids transported in piping systems according ANSI A13.1 version 1996 and 2015 are indicated below.
ANSI A13.1-1996
Fluid Service | Color Code |
Material Inherently Hazardous | Yellow/Black |
Flammable or Explosive Chemical Active or Toxic Extreme Temp. of Pressures Radioactive | Yellow/Black |
Material of Inherently Low Hazard | Green/White |
Liquid or Liquid Admixtures | Green/White |
Material of Inherently Low Hazard | Blue/White |
Gas or Gaseous Admixtures | Blue/White |
Fire Quenching Fluids | Red/White |
Water, Foam, CO2, Halon, etc | Red/White |
ANSI A13.1-2015
Flammable & Oxidizing Fluids | Yellow/Black |
Potable, Cooling, Boiler Feed & Other Waters | Green/White |
Compressed Air | Blue/White |
Toxic and Corrosive Fluids | Orange/Black |
Combustible Fluids | Brown/White |
Defined by User | White/Black |
Defined by User | Gray/White |
Defined by User | Black/White |
Possible (not mandatory) use of color codes for different types of applications are indicated below.
Color Code | ||
Fluid | ANSI 13.1 - 1996 | ANSI 13.1 - 2015 |
Acetic Acid | Yellow/Black | Orange/Black |
Acetone | Yellow/Black | Yellow/Black |
Acetylene Gas | Yellow/Black | Yellow/Black |
Air | Green/White | Blue/White |
Alcohol | Yellow/Black | Yellow/Black |
Alum | Green/White | |
Ammonium Nitrate | Yellow/Black | Yellow/Black |
Amyl Acetate | Yellow/Black | Yellow/Black |
Antidote Gas | Blue/White | |
Argon | Green/White | |
Benzol | Yellow/Black | Yellow/Black |
Bisulphite Liquor | Yellow/Black | Yellow/Black |
Blau Gas | Yellow/Black | Yellow/Black |
Bleach Liquor | Yellow/Black | Yellow/Black |
Blow-off Water | Yellow/Black | Green/White |
Boiler Feed Water | Yellow/Black | Green/White |
Brine | Green/White | Green/White |
Burner Gas | Yellow/Black | Brown/White |
Butane | Yellow/Black | Brown/White |
Butyl Alcohol | Yellow/Black | Yellow/Black |
Calcium Chloride | Blue/White | Orange/Black |
Carbon Bisulphide | Yellow/Black | Orange/Black |
Carbon Dioxide | Yellow/Black | Orange/Black |
Carbon Monoxide | Yellow/Black | Orange/Black |
Carbonated Water | Green/White | Green/White |
Caustic Soda | Yellow/Black | Orange/Black |
Chlorine | Yellow/Black | Orange/Black |
Chlorine Gas | Yellow/Black | Orange/Black |
Chloroform | Yellow/Black | |
Circulating Water | Green/White | Green/White |
City Gas | Yellow/Black | Brown/White |
City Water | Green/White | Green/White |
Coal Gas | Yellow/Black | Brown/White |
Cold Water | Green/White | Green/White |
Compressed Air | Green/White | |
Condensate | Yellow/Black | Green/White |
Cooling Water | Green/White | Green/White |
Cottonseed oil | Yellow/Black | |
Cutting Oil | Green/White | |
Diesel Oil | Yellow/Black | Brown/White |
Distilled Water | Green/White | Green/White |
Drain Oil | Yellow/Black | |
Drain Water | Green/White | Green/White |
Drinking Water | Green/White | Green/White |
Dye | Yellow/Black | Orange/Black |
Ethan Dye | Yellow/Black | Orange/Black |
Exhaust Air | Green/White | |
Exhaust Gas | Yellow/Black | |
Exhaust System | Yellow/Black | |
Filtered Water | Blue/White | Green/White |
Fire Protection Water | Red/White | Red/White |
Flue Gas | Yellow/Black | |
Foamite | Red/White | |
Formalin | Yellow/Black | |
R-12 dichlorodifluoromethane | Green/White | |
Fresh Water | Green/White | Green/White |
Fuel Gas | Yellow/Black | Brown/White |
Fuel oil | Yellow/Black | Brown/White |
Gasoline | Yellow/Black | Brown/White |
Glycerine | Green/White | |
Heating Returns | Yellow/Black | Green/White |
Heating Steam | Yellow/Black | |
Helium | Green/White | |
Hot Water | Yellow/Black | Green/White |
Hydrochloric Acid | Yellow/Black | Orange/Black |
Hydrogen | Yellow/Black | Yellow/Black |
Hydrogen Peroxide | Yellow/Black | Orange/Black |
Hydrogen Sulphide | Yellow/Black | Orange/Black |
Industrial Water | Green/White | Green/White |
Instrument Air | Green/White | Blue/White |
Kerosone | Yellow/Black | Brown/White |
Lacquer | Yellow/Black | Yellow/Black |
Lactic Acid | Yellow/Black | Orange/Black |
Linseed Oil | Yellow/Black | Yellow/Black |
Lubricating Oil | Yellow/Black | |
Make-up Water | Green/White | Green/White |
Mercury | Yellow/Black | |
Methyl Chloride | Yellow/Black | Orange/Black |
Mixed Acid | Yellow/Black | Orange/Black |
Mixed Gas | Yellow/Black | |
Monoethanolamine | Green/White | |
Muriatic Acid | Yellow/Black | Orange/Black |
Naphtha | Yellow/Black | Yellow/Black |
Natural Gas | Yellow/Black | Brown/White |
Nitric Acid | Yellow/Black | Orange/Black |
Nitrogen | Green/White | |
Nitrogen Oxide | Yellow/Black | |
Oil, lubricating | Yellow/Black | Yellow/Black |
Oil, soluble | Yellow/Black | Yellow/Black |
Oxygen | Yellow/Black | Yellow/Black |
Paint | Yellow/Black | Yellow/Black |
Peanut Oil | Yellow/Black | Yellow/Black |
Phenol | Yellow/Black | Yellow/Black |
Process Gas | Yellow/Black | Yellow/Black |
Producer Gas | Yellow/Black | Yellow/Black |
Propane Gas | Yellow/Black | Brown/White |
Raw Water | Green/White | Green/White |
Refrigerated Water | Green/White | Green/White |
River Water | Green/White | Green/White |
Salt Water | Green/White | Green/White |
Sanitary Sewer | Green/White | Green/White |
Soda Ash | Green/White | Orange/Black |
Solvent | Yellow/Black | Yellow/Black |
Soybean Oil | Yellow/Black | Yellow/Black |
Sprinkler Water | Red/White | Red/White |
Storm Sewer | Green/White | Green/White |
Sugar Juice | Green/White | |
Sulhur Chloride | Yellow/Black | Orange/Black |
Sulphur Dioxide | Yellow/Black | Orange/Black |
Sulphuric Acid | Yellow/Black | Orange/Black |
Tar | Yellow/Black | |
Toluene | Yellow/Black | Yellow/Black |
Toluol | Yellow/Black | Yellow/Black |
Trichlorethylene | Yellow/Black | Yellow/Black |
Turpentine | Yellow/Black | Yellow/Black |
Vapor | Yellow/Black | |
Varnish | Yellow/Black | Yellow/Black |
Vegetable Oil | Yellow/Black | Yellow/Black |
Waste Water | Green/White | Green/White |
Water Gas | Yellow/Black | Brown/White |
• Codes and Standards
Color Mixing Theory
Subtractive and additive color mixing.
Hazardous Areas - European Classification Standard
European hazardous area classification with zones, protection types, temperature codes and codes.
Hazardous Areas - North America Classification
North American hazardous locations classification with classes, divisions and groups
Pipe Legends - Identification Scheme
Color codes, field and legend.
Refrigerants - Color Codes
Common refrigerants and their color codes.
