ISA Instrumentation Codes used in Process Control Systems
Process Variable | Symbol | Type of Instrument | Symbol |
Analyses | A | Alarm | A |
Burner | B | Users Choice | B |
Combustion | B | Controller | C |
Users Choice | C | Control valve | CV |
Users Choice | D | Trap | CV |
Voltage | V | Sensor (primary element) | E |
Flow Rate | F | Rupture disc | E |
Users Choice | G | Sight or gage glass | G |
Current (electric) | I | Monitor | G |
Power | J | Indicator | I |
Time | K | Control Station | K |
Level | L | Light (pilot/operation) | L |
Users Choice | M | Users Choice | N |
Users Choice | N | Flow Resistance Orifice | O |
Users Choice | O | Test point (sample point) | P |
Pressure / Vacuum | P | Recorder | R |
Radiation | R | Switch | S |
Speed (or Frequency) | S | Transmitter | T |
Temperature | T | Multifunction | U |
Multivariable | U | Valve/Damper | V |
Vibration | V | Well | W |
Weight (force) | W | Unclassified | X |
Unclassified | X | Relay | Y |
Event | Y | Driver | Z |
Position, dimension | Z | Actuator | Z |
Example - ISA symbols for a Level Indicator
A level indicator will receive the symbol "L" for the process variable "Level", and "I" for the "Indicator" type of instrument. Both combines to:
LI |
For unique identification within a system it is common to add a number to the ISA code, by example the code for level indicator no. eight may be:
LI 08 |
• Documentation
Documentation of process control systems - Block Flow Diagrams (BFD), Process Flow Diagrams (PFD), Piping and Instrumentation Diagrams (P&ID) and more
• Process Control
Instrumentation and process control systems - design and documentation.
BFD - Block Flow Diagram
A Block Flow Diagram is a schematic illustration of a major process.
Greek Alphabet
The Greek alphabet is essential expressing formulas and in technical language.
IP - Ingress Protection Ratings
IP - Ingress Protection rating is used to specify the environmental protection - or electrical enclosure - of electrical equipment.
Draw P&ID diagrams online in the browser with Google Docs.
PFD - Process Flow Diagram
The Process Flow Diagram (PFD) is a schematic illustration of a system.
Process Controllers - P, PI & PID
ISA process instrumentation codes - and combinations.
