Greek Alphabet
The Greek alphabet is derived from the Phoenician alphabeth and has been used to write the Greek language since the 8th century BC.
The table below can used to find the right characters or codes to express the Greek alphabet in html documents or similar.
Adding the Entity, Decimal or Hex expressions directly in the html code will render the letter in a web browser as shown in 1).
Formatting a normal character as "Symbol font" will render the character as shown in 2).
Note! Not all browsers may render the codes and fonts properly.
Character | Entity | Decimal | Hex | Rendering in Your Browser 1) | Rendering with the Symbol Font 2) | |||
Entity | Decimal | Hex | Normal font | Symbol font | ||||
Greek capital letter alpha |
Α | Α | Α | Α | Α | Α | A | A |
Greek capital letter beta |
Β | Β | Β | Β | Β | Β | B | B |
Greek capital letter gamma |
Γ | Γ | Γ | Γ | Γ | Γ | G | G |
Greek capital letter delta |
Δ | Δ | Δ | Δ | Δ | Δ | D | D |
Greek capital letter epsilon |
Ε | Ε | Ε | Ε | Ε | Ε | E | E |
Greek capital letter zeta |
Ζ | Ζ | Ζ | Ζ | Ζ | Ζ | Z | Z |
Greek capital letter eta |
Η | Η | Η | Η | Η | Η | H | H |
Greek capital letter theta |
Θ | Θ | Θ | Θ | Θ | Θ | Q | Q |
Greek capital letter iota |
Ι | Ι | Ι | Ι | Ι | Ι | I | I |
Greek capital letter kappa |
Κ | Κ | Κ | Κ | Κ | Κ | K | K |
Greek capital letter lambda |
Λ | Λ | Λ | Λ | Λ | Λ | L | L |
Greek capital letter mu |
Μ | Μ | Μ | Μ | Μ | Μ | M | M |
Greek capital letter nu |
Ν | Ν | Ν | Ν | Ν | Ν | N | N |
Greek capital letter xi |
Ξ | Ξ | Ξ | Ξ | Ξ | Ξ | X | X |
Greek capital letter omicron |
Ο | Ο | Ο | Ο | Ο | Ο | O | O |
Greek capital letter pi |
Π | Π | Π | Π | Π | Π | P | P |
Greek capital letter rho |
Ρ | Ρ | Ρ | Ρ | Ρ | Ρ | R | R |
Greek capital letter sigma |
Σ | Σ | Σ | Σ | Σ | Σ | S | S |
Greek capital letter tau |
Τ | Τ | Τ | Τ | Τ | Τ | T | T |
Greek capital letter upsilon |
Υ | Υ | Υ | Υ | Υ | Υ | U | U |
Greek capital letter phi |
Φ | Φ | Φ | Φ | Φ | Φ | F | F |
Greek capital letter chi |
Χ | Χ | Χ | Χ | Χ | Χ | C | C |
Greek capital letter psi |
Ψ | Ψ | Ψ | Ψ | Ψ | Ψ | Y | Y |
Greek capital letter omega |
Ω | Ω | Ω | Ω | Ω | Ω | W | W |
Greek small letter alpha |
α | α | α | α | α | α | a | a |
Greek small letter beta |
β | β | β | β | β | β | b | b |
Greek small letter gamma |
γ | γ | γ | γ | γ | γ | g | g |
Greek small letter delta |
δ | δ | δ | δ | δ | δ | d | d |
Greek small letter epsilon |
ε | ε | ε | ε | ε | ε | e | e |
Greek small letter zeta |
ζ | ζ | ζ | ζ | ζ | ζ | z | z |
Greek small letter eta |
η | η | η | η | η | η | h | h |
Greek small letter theta |
θ | θ | θ | θ | θ | θ | q | q |
Greek small letter iota |
ι | ι | ι | ι | ι | ι | i | i |
Greek small letter kappa |
κ | κ | κ | κ | κ | κ | k | k |
Greek small letter lambda |
λ | λ | λ | λ | λ | λ | l | l |
Greek small letter mu |
μ | μ | μ | μ | μ | μ | m | m |
Greek small letter nu |
ν | ν | ν | ν | ν | ν | n | n |
Greek small letter xi |
ξ | ξ | ξ | ξ | ξ | ξ | x | x |
Greek small letter omicron |
ο | ο | ο | ο | ο | ο | o | o |
Greek small letter pi |
π | π | π | π | π | π | p | p |
Greek small letter rho |
ρ | ρ | ρ | ρ | ρ | ρ | r | r |
Greek small letter final sigma |
ς | ς | ς | ς | ς | ς | z | z |
Greek small letter sigma |
σ | σ | σ | σ | σ | σ | s | s |
Greek small letter tau |
τ | τ | τ | τ | τ | τ | t | t |
Greek small letter upsilon |
υ | υ | υ | υ | υ | υ | u | u |
Greek small letter phi |
φ | φ | φ | φ | φ | φ | j | j |
Greek small letter chi |
χ | χ | χ | χ | χ | χ | c | c |
Greek small letter psi |
ψ | ψ | ψ | ψ | ψ | ψ | y | y |
Greek small letter omega |
ω | ω | ω | ω | ω | ω | w | w |
Scientific and Engineering use of the Greek Alphabet
Character | Symbol | Typically Used For |
α | Angles, angular acceleration |
β | Angles, coefficients |
γ | Shear strain, kinematic viscosity |
δ | Differences, damping coefficient |
ε | Linear strain |
ζ | |
η | Dynamic viscosity, efficiency |
θ | Angles, temperature |
ι | |
κ | Compressibility of fluids |
λ | Wavelength, thermal conductivity |
μ | Coefficient of friction, dynamic viscosity, Poisson's ratio |
ν | Kinematic viscosity |
ξ | |
ο | |
π | Mathematical constant |
ρ | Density |
ς | |
σ | Normal stress, standard deviation |
τ | Shear stress |
υ | |
φ | Angles, flow rate, potential energy |
χ | |
ψ | Gears helix angle |
ω | Angular velocity, solid angle |
ASCII Codes
ASCII codes and characters.
Binary to Decimal, Hexadecimal and ASCII Converter
Convert between binary, decimal and hexadecimal numbers.
Constants of π
The mathematical π constants.
HVAC Abbreviations
Commonly used HVAC abbreviations.
ISA Instrumentation Codes used in Process Control Systems
The ISA standards and symbols are important for the P&IDs and documents describing the process control system.
Morse Code Alphabet
The morse code alphabet.
Draw P&ID diagrams online in the browser with Google Docs.
PFD - Process Flow Diagram - Online Drawing Tool
Draw Process Flow Diagrams with this online Google Docs drawing application.
Phonetic Alphabet
The phonetic alphabet used in international aircraft communications.
ISA process instrumentation codes - and combinations.
SI System
An introduction to the SI metric system.
Symbols Used to Denote a Chemical Reactions and Process or Condition
Explanation of symbols used as subscripts or superscripts to tell more about the type of chemical reaction, process or condition.
