Binary to Decimal, Hexadecimal and ASCII Converter
Binary - to Decimal, Hexadecimal and ASCII Converter
Click on the binary number buttons to toggle between 0 and 1 for each bit:
unsigned
binary number
(8 bits, one byte)
27 26 25 24 23 22 21 20
128 64 32 16 8 4 2 1
decimal number 0
hexadecimal number 0
ASCII
A binary number is a number expressed in the binary numeral system or base 2 numeral system. A binary number can express any number by using only two digits: 0 and 1. The calculator above converts binary numbers with 1 to 8 bits (one byte) to the decimal or hexadecimal equivalents.
The default 8 bit (one byte) binary number 10100100 is calculated to the decimal equivalent:
10100100
= 1 × 27 + 0 × 26 + 1 × 25 + 0 × 24 + 0 × 23 + 1 × 22 + 0 × 21 + 0 × 20
= 128 + 0 + 32 + 0 + 0 + 4 + 0 + 0
= 164
8 bits or byte can be used to represent an ASCII (American Standard Code for Information Interchange) alphabetic character - like the binary number 01000001, or decimal number 65, representing A.
Decimal - to Binary, Hexadecimal and ASCII Converter
decimal number
binary number
hexadecimal number
ASCII
The standard numeral system is called decimal with base 10 and uses 10 symbols: 0,1,2,3,4,5,6,7,8,9.
Hexadecimal - to Binary, Decimal and ASCII Converter
hexadecimal number
binary number
decimal number
ASCII
The hexadecimal (also base 16, or hex) is a positional numeral system with base 16.
The hexadecimal system use sixteen distinct symbols with 0–9 representing the values zero to nine and A, B, C, D, E, F (or a, b, c, d, e, f) representing the values ten to fifteen.
The default hexadecimal number  a4 from the calculator above can be converted to its decimal equivalent:
a4
= a16 × 161 + 416 × 160
= 10 × 161 + 4 × 16
= 160 + 4
= 164
The hexadecimal number a4 from the calculator above can be converted to its decimal equivalent:
a4b3
= a16 × 163 + 416 × 162 + b16 × 161 + 316 × 160
= 10 × 163 + 4 × 162 + 11 × 161 + 3 × 16
=40960 + 1024 + 176 + 3
= 42163
Hexadecimal vs. Decimal and Binary Numbers
Hexadecimal Number
0 1 2 3 4 5 6 7 8 9 a b c d e f
Decimal Number
0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
Binary Number
0000 0001 0010 0011 0100 0101 0110 0111 1000 1001 1010 1011 1100 1101 1110 1111
Each hexadecimal digit represents four binary bits - a nibble. Four digital bits can represent up to 16 different values. Two nibbles with 8 bits is a byte. Computers use mostly bytes or multiplies of bytes (16, 32, 64 .. bits) in their operations.
Binary representation of the hexadecimal number
a4
= 1010 0100
a4b3
= 1010 0100 1011 0011
Mathematics
ASCII Codes
ASCII codes and characters.
Binary Adding, Subtraction, Multiplicaton and Division
Adding, subtracting, multiplying and dividing binary numbers.
Binary, Octal and Hexadecimal Numbers
Decimal, binary, octal and hexadecimal numbers.
Boolean Algebra
Logic functions where the values of variables are true (1) or false (0).
Bytes, Kilobytes and Megabytes
Computer bytes.
Data Types
Signed vs. unsigned datatypes.
Designation of Large Numbers
Designation of large number in US vs. other countries.
Greek Alphabet
The Greek alphabet is essential expressing formulas and in technical language.
HTML Color Codes
Safe html color codes.
Prefixes for Binary Multiplies
IEC International Standard names and symbols
