+ 6
= 11
Rule to follow when binary numbers are subtracted:
Decimal | Binary | |
1 | 9 - 5 = 4 | 1001 - 101 = 0100 |
2 | 16 - 3 = 13 | 10000 - 11 = 01101 |
3 | 6.25 - 4.50 = 1.75 | 110.01 - 100.10 = 001.11 |
Rule to follow when binary numbers are multiplied:
Rule to follow when binary numbers are divided:
Convert between binary, decimal and hexadecimal numbers.
Decimal, binary, octal and hexadecimal numbers.
Prefix names used for multiples and submultiples units.
IEC International Standard names and symbols
Online scientific calculator.
