Note that the calculator relies on the syntax of javascript. The constants and the syntax for the mathematical functions are explained below.
Some simple expressions:
- 23 = pow(2,3) = 8
- log(3) = 1.099
- 2 * (3 + 2) = 10
A more complicated formula for calculating the pressure drop in compressed air pipe lines (using same values as the link)
Note that the expressions can be written in any editor and transferred to the calculator display by using "copy and paste".
This calculator can handle input numbers in several different bases:
^ is a bitwise xor operation. To raise a number to a power use pow() function.
to ostermiller.org for providing this calculator under the terms of the GNU General Public License as quoted below:
"This program is free software; you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation; either version 2 of the License, or (at your option) any later version.
This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details."
Adding, subtracting, multiplying and dividing binary numbers.
The mathematical π constants.
The mathematical e constants.
Calculate the arithmetic mean, median and modal values from discrete data sets.
