HVAC Abbreviations
  • A - compressed air line or area
  • ABC - above ceiling
  • AC - air chamber, alternating current
  • A/C - air conditioning
  • AFF - above finished floor
  • AFG - above finished grade
  • AL - aluminum
  • AMB - ambient
  • AMP - ampere
  • ARR - arrangement
  • ATC - automatic temperature control, at ceiling
  • ATM - atmosphere
  • AUTO - automatic
  • AUX - auxiliary
  • AVG - average
  • BBD - boiler blowdown
  • BF - boiler feed
  • BHP - boiler horsepower, brake horsepower
  • BOD - bottom of duct
  • BOP - bottom of pipe
  • BOT - bottom
  • BP - back pressure
  • B & S - bell-and-spigot
  • BSMT - basement
  • BTU - British thermal unit
  • BV - butterfly valve
  • oC - degrees Celsius
  • C - condensate line
  • C to C - center to center
  • CA - compressed air
  • CAL - calorie
  • CAP - capacity
  • CD - condensate drain
  • CF - chemical feed, cubic foot
  • CFH - cubic feet per hour
  • CFM - cubic feet per minute
  • CI - cast iron
  • CIRC - circular
  • CL - center line
  • CM - centimetre
  • CM2 - square centimetre
  • CO - clean out
  • COL - column
  • CONC - concrete, concentric
  • CONN - connect, connection
  • CONT - continuation
  • CPVC - chlorinated polyvinyl chloride
  • CR - condenser return
  • CRW - chemical resistant waste
  • CS - condenser supply
  • CTR - center
  • CU - cubic
  • CU FT. - cubic feet
  • CU IN. - cubic inches
  • CV - check valve
  • CW - cold water
  • CWR - cold water riser
  • CWR - chileld/cold water return
  • CWS - chilled/cold water supply
  • D - drain, deep
  • DB - dry bulb
  • DDC - direct digital control
  • DEG - degree
  • DELTAT - temperature difference
  • DET - detail
  • DIA - diameter
  • DISC - disconnect
  • DN - down
  • DP - dew point temperature
  • DR - drain
  • DWG - drawing
  • EA - exhaust air, each
  • EAT - entering temperature
  • EATR – Exhaust Air Transfer Ratio - to identify the amount of exhaust air transferred to inlet air in an energy recovery ventilator
  • E to C - end to center
  • EER - energy efficient ratio
  • EFF - efficiency
  • EJ - expansion joint
  • EL - elevation
  • ELB - elbow
  • ELEC - electrical
  • ENT - entering
  • ERV – Energy Recovery Ventilator
  • ESP - external static pressure
  • ET - expansion tank
  • EVAP - evaporator
  • EWT - entering water temperature
  • EXH - exhaust
  • EXP - expansion
  • EXST - existing
  • EXT - external
  • oF - degrees Fahrenheit
  • F - Fahrenheit
  • FC - flexible connector, flexible connection
  • FCO - floor clean out
  • FD - floor drain
  • FDW - feed water
  • FEC - fire extinguisher cabinet
  • FF - finish floor
  • FG - finish grade
  • FHC - fire hose cabinet
  • FLA - full load amps
  • FLR - floor
  • FM - flow meter
  • FO - fuel oil
  • FOV - flush out valve
  • FPM - feet per minute
  • FPS - feet per second
  • FS - flow switch, federal specs
  • FT - foot, feet
  • FTG - fitting
  • FU - fixture unit
  • FV - flush valve
  • G - gram, gas line
  • GA - gauge
  • GAL - gallons
  • GALV - galvanized
  • GL.V - globe valve
  • GND - ground
  • GPD - gallons per day
  • GPH - gallons per hour
  • GPM - gallons per minute
  • GPS - gallons per second
  • GR - grain
  • GV - gate valve
  • GWH - gas water heater
  • H2O - water
  • HB - hose bibb
  • HD - head
  • Hg - mercury
  • HGT - height
  • HMD - humidity
  • HORIZ - horizontal
  • HP - horsepower
  • HR - hour
  • HRV – Heat Recovery Ventilator
  • HTD - heated
  • HTR - heater
  • HW - hot water
  • HWH - hot water heater
  • HWR - hot water return, hot water riser
  • HWS - hot water supply
  • HWT - hot water tank
  • HZ - herts
  • ID - inside diameter
  • IN. - inch
  • INHg - inches of mercury
  • INSUL - insulation
  • INT - international
  • INTL - internal
  • IPS - iron pipe size
  • IV - indirect vent
  • IW - indirect waste
  • J - joule
  • K - kelvin
  • KG - kilogram
  • KM - kilometre
  • KM2 - square kilometre
  • KPA - kilo pascal
  • KS - kitchen sink
  • KW - kilowatt
  • L - length, liter
  • LAT - leaving air temperature
  • LB. - pound
  • LBF - pound-force
  • LIQ - liquid
  • LP - low pressure
  • LRA - locked rotor amps
  • LVL - level
  • LVR - louver
  • LWT - leaving water temperature
  • M - meter
  • M2 - square meter
  • M TYPE - lightest type of rigid copper pipe
  • MAN - manual
  • MAT - mixed air temperature
  • MAX - maximum
  • MBH - thousand British thermal units per hour
  • MFR - manufacturer
  • MG - milligram
  • MGD - millions gallons per day
  • MIN - minimum or minute
  • ML - milliliter
  • MM - millimetre
  • MM3 - cubic millimetre
  • MPT - male pipe thread
  • MTD - mounted
  • MU - make up
  • NA - not applicable
  • NC - normally closed
  • NEG - negative
  • NIC - not in contact
  • NO - normally open
  • NPHP - name plate horsepower
  • NPS - nominal pipe size
  • NPSH - net positive suction head
  • NTS - not to scale
  • O - oxygen
  • OA - outside air
  • OAT - outside temperature
  • OC - on center
  • OD - outside diameter
  • OED - open end duct
  • OF - overflow
  • OV - outlet velocity
  • OZ. - ounce
  • PA - pascal
  • PC - plumbing contractor
  • PCR - pumped condensate return
  • PD - pressure drop
  • PF - power factor
  • PG - pressure gauge
  • PL - plate
  • PNEU - pneumatic
  • PRESS - pressure
  • PROP - propeller
  • PRV - pressure reducing valve
  • PSI - pounds per square inch
  • PSIA - pound per square inch absolute
  • PSIG - pound per square inch gauge
  • PV - plug valve
  • QTY - quantity
  • RA - return air
  • RAD - radius
  • RAT - return air temperature
  • RD - roof drain
  • R/E - return and exhaust
  • RECOV - recovery
  • RED - reducer
  • REF - reference
  • RH - relative humidity
  • REQD - required
  • REV - revision
  • RL - refrigerant liquid
  • RLA - Rated Load Amperes
  • RM - room
  • RS - refrigerant suction
  • RTN - return
  • RV - relief valve
  • S - switch
  • SA - shock absorber, supply air
  • SAT - supply air temperature
  • SCH - schedule
  • SDT - saturated discharge temperature
  • SEC - seconds, secondary
  • SENS - sensible
  • SEP - separate
  • SEQ - sequence
  • SER - series
  • SERV - service
  • SF - service factor
  • SHT - sheet
  • SI - international systems of units
  • SOL - solenoid
  • SP - static pressure
  • SPEC - specification
  • SQ. - square
  • SQ.FT. - square feet
  • SS - stainless steel
  • SSH - static suction head
  • SST - saturated suction temperature, stainless steel
  • STD - standard
  • STH - static total head
  • STL - steel
  • SUCT - suction
  • SPLY - supply
  • SV - service
  • SVH - static velocity head
  • SW - service weight
  • SWS - service water
  • TD - temperature difference
  • TDH - total dynamic head
  • TEMP - temperature
  • TH - thermometer
  • THK - thick
  • TP - total pressure
  • TSP - total static pressure
  • UF - under floor
  • UH - unit heater
  • V - vent, volt, volume
  • VAC - vacuum
  • VAV - variable air volume
  • VB - vacuum breaker
  • VCI - vacuum cleaning inlet
  • VCL - vacuum cleaning line
  • VEL - velocity
  • VERT - vertical
  • VIB - vibration
  • VOL - volume
  • VSD - variable speed drive
  • VP - velocity pressure
  • VTR - vent thru roof
  • W - watt, width, wide
  • WB - wet bulb
  • WCO - wall clean out
  • WG - water gauge
  • WH - water heater
HVAC Systems
Design and sizing of Heating, Ventilation and Air Conditioning systems.
Piping Codes and Standards
Process Control Systems Documentation
Documentation of process control systems - Block Flow Diagrams (BFD), Process Flow Diagrams (PFD), Piping and Instrumentation Diagrams (P&ID) and more.
Cooling and Heating Equations
Cooling Load - Latent and Sensible Heat
Latent and sensible cooling loads to consider when designing HVAC systems.
Greek Alphabet
The Greek alphabet is essential expressing formulas and in technical language.
Sensible Heat Ratio - SHR
The ratio Sensible Heat (or Cooling) Load to the Total Heat (or Cooling) Load.
Static Pressure in a HVAC System
A minimum static pressure is required in a HVAC system to keep the water in the highest levels of the system.
