The unit of heat in the imperial system - the BTU - is
An item using one kilowatt-hour of electricity generates 3412 Btu.
A calorie is commonly defined as
Be aware that alternative definitions exists - in short:
The calorie is outdated and commonly replaced by the SI-unit Joule.
The unit of heat in the SI-system the Joule is
Heating systems - capacity and design of boilers, pipelines, heat exchangers, expansion systems and more.
Electric heating of an object or mass - temperature change vs. energy supplied.
Energy density - by weight and volume - for some ways to store energy
Heat vs. work vs. energy.
Pasteurization methods, time and temperatures.
Standardized enthalpies and entropies for some common substances.
Calculate steam flow rate vs. kW rating.
Energy stored as sensible heat in materials.
