Electric Heating of Mass
When an electric heater heats an object - the electric energy is transformed to heat by increased object temperature. The electric energy used equals the change in thermal energy and can be expressed as:
P t μ = U I t μ
= c m dT                                (1)
electric energy supplied = thermal energy change in object
P = power (watts, W)
U = potential difference (volts, V)
I = electrical current (amps, A)
t = time (sec)
μ = heating efficiency
c = specific heat of the heated substance (J/kgoC)
m = mass of the heated substance (kg)
dT = temperature differance (oC)
Example - 12 Volt Car Water Heater
The temperature change in a 12 volts and 10 amps Car Water Heater (100% efficient => μ = 1) with 0.4 kg water and 5 minutes heating period can be calculated by modifying (1) to
dT = U I t μ / c m
   = (12 volts) (10 amps) (300 sec) 1 / (4200 J/kgoC) (0.4 kg)
   = 21.4 oC
Note! The mass of the water heater and the heat loss from the heater during heating is neglected in the calculation. In reality the mass of the heater and the heat loss from the heater during the heating process will influence the temperature change.
Electric Heat Calculator
This calculator can be used to calculate temperature rise in an electric heated object or mass. Heat loss during heating is neglected.
Electrical
Electrical units, amps and electrical wiring, wire gauge and AWG, electrical formulas and motors.
Thermodynamics
Thermodynamics of steam and condensate systems.
Cooling and Heating Equations
Heat, Work and Energy
Heat vs. work vs. energy.
Heating Up Applications - Energy Required and Heat Transfer Rates
Energy required to heat up a substance.
Liquids and Fluids - Specific Heats
Solids - Specific Heats
Specific Heat of common Substances
Storing Thermal Heat in Materials
Energy stored as sensible heat in materials.
Units of Heat - BTU, Calorie and Joule
The most common units of heat BTU - British Thermal Unit, Calorie and Joule.
Water - Thermophysical Properties
