Heating Up Applications - Energy Required and Heat Transfer Rates
The energy required to heat up a substance - like a tank, swimming pool or similar - within a certain time can be calculated as
q = m cp dT / t (1)
q = mean heat transfer rate (kW)
m = mass of substance (kg)
cp = specific heat of the substance (kJ/kg oC)
dT = temperature difference (oC)
t = heat up time (s)
Note that heat loss to the surroundings will extend the heat up time.
Example - Heating up an Aluminum Saucepan filled with Cold Water
An aluminum saucepan with weight 2 kg is filled with 10 liter cold water with temperature 0 oC and heated to temperature 100oC (boiling) in one hour. The heat transfer rate (or required power) can be calculated as
q = (( (10 liter) (1 kg/liter) (4.2 kJ/kgoC) + (2 kg) (0.91 kJ/kgoC)) ( (100 oC) - (0 oC))) / ((1 h) 3600 (s/h))
= 1.2 kW
The energy consumed can be calculated as
E = q t (2)
E = energy (kJ, kWs)
t = time (h)
- or, with values
E = (1.2 kW) (1 h)
= 1.2 kWh
• Thermodynamics
Carnot Cycle Efficiency
Cooling Load - Latent and Sensible Heat
Latent and sensible cooling loads to consider when designing HVAC systems.
Electric Heating of Mass
Electric heating and temperature change vs. energy supplied.
Energy Transfer Equation
Fluid energy transfer.
Heat, Work and Energy
Heat vs. work vs. energy.
Heating System Flow Rates
Calculate flow rates in heating systems.
Heating Systems - Steam and Condensate Loads
Hot Water Heating System Online Design Application
Specific Heat of Common Liquids and Fluids
Specific Heat of Common Materials – Engineering Reference
