Carnot Cycle Efficiency
An ideal reversible cycle where heat is taken in at constant upper temperature and rejected at constant lower temperature was suggested by Sadi Carnot. The theoretically most efficient heat engine cycle, the Carnot cycle, consists of
- two isothermal processes and
- two adiabatic processes
Since the second law of thermodynamics states that not all supplied heat in a heat engine can be used to do work the Carnot efficiency limits the fraction of heat that can be used.
The Carnot efficiency can be expressed as
μC = (Ti - To) / Ti (1)
μC = efficiency of the Carnot cycle
Ti = temperature at the engine inlet (K)
To = temperature at engine exhaust (K)
The wider the range of temperature, the more efficient becomes the cycle. The lowest temperature is limited by the temperature of the sink of heat - if it is the atmosphere or the ocean, river or whatever available. Normally the lowest temperature available is in the range 10 - 20 oC. The maximum temperature is limited by the metallurgical strength of the available materials.
• Thermodynamics
1st Law of Thermodynamics
2nd Law of Thermodynamics
Entropy and disorder.
Carnot, Otto, Diesel and Joule Cycles
Pressure Volume (PV) and Temperature Entropy (TS) diagrams for the Carnot, Otto, Diesel and Joule cycles.
Compression and Expansion of Gases
Isothermal and isentropic gas compression and expansion processes.
Dalton's Law
Gibbs' Dalton's law of the total pressure of a mixture of gases.
Efficiency
The measure of usefulness.
Efficiency
Efficiency is the ratio useful energy output to energy input.
Energy Transfer Equation
Fluid energy transfer.
Heat, Work and Energy
Heat vs. work vs. energy.
Heating Up Applications - Energy Required and Heat Transfer Rates
Energy required to heat up a substance.
Power Plants - Performance Efficiencies
Power plants heat rates, thermal efficiencies, capacity factors, load factors, economic efficiencies, operational efficiencies and energy efficiencies.
Rankine Efficiency
The efficiency of the Rankine cycle.
Thermal Transmittance vs. Thermal Resistance
The thermal transmittance U vs. the thermal resistance R.
