Thermal Transmittance vs. Thermal Resistance
Thermal transmittance related to thermal resistance can be expressed as
U = 1 / R                                  (1)
U = overall thermal transmittance (W/m2 oC)
R = overall thermal resistance (m2oC/W)
Thermal resistance can be expressed by transforming (1) to
R = 1 / U                                 (1b)
The overall thermal transmittance from a layered construction with individual thermal resistances - like a wall with insulation and outside and inside cladding - can be expressed as
U = 1 / ΣRi                                (2)
Example - Thermal Transmittance in Heat Exchanger
The thermal transmittance in an heat exchanger can be calculated as
U = 1 / (Rair film + Rcondensate film + Rmetal wall + Rproduct film)
Thermodynamics
Carnot Cycle Efficiency
Conductive Heat Transfer
Overall Heat Transfer Coefficient: Definitions, Values & Applications
Thermal Conductivity of Common Materials - Solids, Liquids and Gases
Thermal conductivity of various common materials, including metals, gases, and building materials. Essential data for engineers, architects, and designers working with heat transfer and insulation.
