The overall heat transfer coefficient for a multi-layered wall, pipe or heat exchanger - with fluid flow on each side of the wall - can be calculated as
1 / U A = 1 / hci Ai + Σ (sn / kn An) + 1 / hco Ao (2)
U = the overall heat transfer coefficient (W/(m2 K), Btu/(ft2 h oF))
kn = thermal conductivity of material in layer n (W/(m K), Btu/(hr ft °F))
hc i,o = inside or outside wall individual fluid convection heat transfer coefficient (W/(m2 K), Btu/(ft2 h oF))
sn = thickness of layer n (m, ft)
A plane wall with equal area in all layers - can be simplified to
1 / U = 1 / hci + Σ (sn / kn) + 1 / hco (3)
Thermal conductivity - k - for some typical materials (not that conductivity is a property that may vary with temperature)
The convection heat transfer coefficient - h - depends on
Convective heat transfer coefficient for some common fluids:
This calculator can be use to calculate the overall heat transfer coefficient and the heat transfer through a multi-layered wall. The calculator is generic and can be used for metric or imperial units as long as the use of units is consistent.
Heat transfer resistance can be expressed as
R = 1 / U (4)
R = heat transfer resistance (m2K/W, ft2 h°F/ Btu)
The wall is split in sections of thermal resistance where
Surface coatings or layers of "burned" product adds extra thermal resistance to the wall decreasing the overall heat transfer coefficient.
An air to air plate exchanger with area 2 m2 and wall thickness 0.1 mm can be made in polypropylene PP, aluminum or stainless steel.
The heat transfer convection coefficient for air is 50 W/m2K. Inside temperature in the exchanger is 100 oC and outside temperature is 20 oC.
The overall heat transfer coefficient U per unit area can be calculated by modifying (3) to
U = 1 / (1 / hci + s / k + 1 / hco) (3b)
The overall heat transfer coefficient for heat exchanger in
UPP = 1 / (1 / (50 W/m2K) + (0.1 mm) (10-3 m/mm)/ (0.1 W/mK) + 1 / (50 W/m2K))
= 24.4 W /m2K
The heat transfer is
q = (24.4 W /m2K) (2 m2) ((100 oC) - (20 oC))
= 3904 W
= 3.9 kW
USS = 1 / (1 / (50 W/m2K) + (0.1 mm) (10-3 m/mm)/ (16 W/mK) + 1 / (50 W/m2K))
= 25 W /m2K
q = (25 W /m2K) (2 m2) ((100 oC) - (20 oC))
= 4000 W
= 4 kW
UAl = 1 / (1 / (50 W/m2K) + (0.1 mm) (10-3 m/mm)/ (205 W/mK) + 1 / (50 W/m2K))
= 25 W /m2K
= 4000 W
= 4 kW
Heat loss from pipes, tubes and tanks - with and without insulation - foam, fiberglass, rockwool and more.
Steam and condensate pipes - heat loss uninsulated and insulated pipes, insulation thickness and more.
Heat transfer and heat loss from buildings and technical applications - heat transfer coefficients and insulation methods to reduce energy consumption.
Convective air flows from typical heat sources like people, computers, radiators and more.
Typical heat exchanger materials and their thermal conductivities.
Heat-transfer in heat exchangers are reduced by fouling.
Overall heat transfer coefficients in common heat exchanger designs - tubular, plate or spiral.
Radiation emissivity of common materials like water, ice, snow, grass and more.
Thermal conductivity coefficients for insulation materials, aluminum, asphalt, brass, copper, steel, gases and more.
Heat transfer coefficients for steam and hot water coils submerged in oil tanks.
The thermal transmittance U vs. the thermal resistance R.
Water condensation on inside glass windows surfaces vs. outside temperature and inside temperature and humidity.
