- ε -
Heat loss from pipes, tubes and tanks - with and without insulation - foam, fiberglass, rockwool and more.
Steam and condensate pipes - heat loss uninsulated and insulated pipes, insulation thickness and more.
Heat transfer and heat loss from buildings and technical applications - heat transfer coefficients and insulation methods to reduce energy consumption.
Solar radiation absorbed by various materials.
Heat loss vs. surface temperature.
Solar heat gain through windows with roller shades, vertical blinds and Venetian blinds
Daily surface energy from solar radiation.
Radiation surface absorptivity.
