Surface Radiation Absorptivity
Absorptivity can be defined as
  • the ratio of power absorbed to the incident radiant power
For emissivity and emitted light absorptivity is the amount of radiation absorbed by a surface compared to what is absorbed by a black body.
SurfaceAbsorptivity
Aluminum, anodized 0.14
Aluminum, dull/rough polished 0.4 - 0.65
Aluminum. polished 0.1 - 0.40
Asbestos Cement, old 0.83
Black matte 0.95
Brick, red 0.65
Chromium plate 0.20
Concrete 0.6
Iron, galvanized old 0.89 - 0.92
Grey paint 0.95
Light green paint 0.95
Limestone 0.33 - 0.53
Red clay brick 0.94
Snow, ice granules 0.33
Steel, galvanized (zink oxide) 0.65
Steel, galvanized weathered 0.8
White paint 0.25 - 0.4
Thermodynamics
Absorbed Solar Radiation
Solar radiation absorbed by various materials.
Emissivity Coefficients of Common Materials: Data & Reference Guide
Radiation - Surface Emissivity Coefficients
Radiation emissivity of common materials like water, ice, snow, grass and more.
Radiation Heat Transfer
Solar Radiation - Daily Surface Energy
Daily surface energy from solar radiation.
Solar Radiation through Windows
Heat from sun transmitted through windows.
