The radiation constant is the product between the Stefan-Boltzmann constant - σ - and the emissivity constant - ε - of a material.
The radiation constant for some typical products:
ProductRadiation Constant
(10-8  W/m2 K4)
Emissivity Constant
- ε -
Black body 5.7 1
Brass, dull 1.3 0.22
Brick, red 5.3 0.93
Cast iron, rough oxidized 5.1 0.9
Copper, polished 0.28 0.04
Cotton 4.4 0.77
Glass 5.1 0.9
Lampblack paint 5.5 0.96
Oil paint 5.4 0.94
Paper 3.1 0.55
Plaster 5.6 0.98
Sand 5.1 0.9
Silk 4.3 0.75
Silver, polished 0.17 0.03
Tin, unoxidized 0.23 0.04
Water, 0 - 100oC 5.4 0.95
Wood 5.1 0.9
Wool 4.3 0.75
Wrought iron, dull oxidized 5.4 0.9
Wrought iron, polished 1.6 0.25
Zinc, tarnished 1.4 0.25
σ = 5.6703 10-8 (W/m2K4) = 0.1714 10-8 (Btu/(h ft2 oR4) ) - Stefan-Boltzmann Constant
ε = emissivity coefficient of the object (ε = 1 for a black body)
Thermodynamics
Absorbed Solar Radiation
Solar radiation absorbed by various materials.
Induction Motors - No. of Poles and Synchronous vs. Full Load Speed
Synchronous and full load speed of amplitude current (AC) induction motors.
Pipes - Bare Surface Heat Loss
Heat loss vs. surface temperature.
Radiation - Surfaces Emissivity Coefficients
Radiation emissivity of common materials like water, ice, snow, grass and more.
Radiation Heat Transfer
Solar Radiation - Daily Surface Energy
Daily surface energy from solar radiation.
Solar Radiation through Windows
Heat from sun transmitted through windows.
Surface Emissivity Coefficients
Surface Radiation Absorptivity
Radiation surface absorptivity.
