Fraction of Incident Radiation Absorbed
(approximated)
Substance | Absorb Factor Fraction of Incident Radiation Absorbed |
Aluminum, polished | 0.30 |
Aluminum paint | 0.20 |
Aluminum, anodized | 0.15 |
Brick, glazed | 0.35 |
Brick, common light red | 0.55 |
Brick, common red | 0.68 |
Brick, wire cut red | 0.52 |
Brick, blue | 0.89 |
Cork | 0.45 |
Limestone, light | 0.35 |
Limestone, dark | 0.50 |
Linoleum, red-brown | 0.84 |
Sandstone, light grey | 0.62 |
Sandstone, red | 0.73 |
Marble, white | 0.44 |
Soft rubber, gray | 0.65 |
Marble, dark | 0.66 |
Granite, reddish | 0.55 |
Magnesium oxide, evaporated | 0.08 |
Graphite | 0.84 |
Porcelain | 0.50 |
Steel, vitreous enameled green | 0.76 |
Steel, vitreous enameled dark red | 0.81 |
Steel, vitreous enameled blue | 0.80 |
Iron, galvanized new | 0.64 |
Iron, galvanized dirty | 0.92 |
Iron, galvanized white washed | 0.22 |
Concrete | 0.60 |
Copper, polished | 0.18 |
Copper, tarnished | 0.64 |
Lead, old | 0.79 |
Asbestos cement, roof tiles old | 0.83 |
Asbestos cement, roof tiles red | 0.69 |
Asbestos slate | 0.81 |
Asphalt roofing, new | 0.91 |
Asphalt roofing, old | 0.82 |
Bitumen-covered roofing sheet, brown | 0.87 |
Slate, blue grey | 0.87 |
Tile, clay red | 0.64 |
Tile, concrete uncolored | 0.65 |
Tile, concrete black | 0.91 |
Vitreous enamel, white | 0.39 |
White Dutch tile | 0.18 |
The electromagnetic spectrum with wavelengths and frequencies.
Optical properties of commonly used glazing materials.
Working activities and light levels - required illuminance.
Energy consumption of lighting systems
Light reflecting factor materials.
Geometric dilution of light vs. distance.
Radiation emissivity of common materials like water, ice, snow, grass and more.
Some common fluids and their refractive index.
Solar heat gain through windows with roller shades, vertical blinds and Venetian blinds
Daily surface energy from solar radiation.
Heat from sun transmitted through windows.
Online solar chart creator.
Radiation surface absorptivity.
