LENI - Lighting Energy Numeric Indicator
The LENI - Lighting Energy Numeric Indicator - stands for the actual energy consumption of a lighting system in kWh per square metre and year - and can be calculated as
LENI = Σ(Pn fc) ((td fo fd) + (tn fo)) / A                          (1)
LENI = lighting energy numeric indicator (kWh/(m2 year))
Pn = installed load (kW)
fc = reducing factor due to use of daylight control (<1)
td = annual hours of use by day (h)
fo = reducing factor due to use of present based control (<1)
fd = reducing factor due to use of constant lighting maintenance control (<1)
tn = annual hours of use by night (h)
A = area (m2)
LENI is according to EN 15193 Energy performance of buildings – Energy requirements for lighting.
Electrical
Absorbed Solar Radiation
Solar radiation absorbed by various materials.
Electrical Equipment - Power Consumption
Typical power consumption and running time for common electrical equipment.
Heat Gain from Lights
Heat contributed by lights may have major impact on air-condition systems.
Heat Losses from Electrical Equipment
Heat loss from electrical equipment like switch-gear, transformers and variable frequency drives.
Illuminance - Recommended Light Levels
Working activities and light levels - required illuminance.
Lights vs. Power Installation
Lights vs. power installations in common types of buildings and rooms.
Luminous Efficacy
The visible light produced by light sources.
Materials - Light Reflecting Factors
Light reflecting factor materials.
