Luminous Efficacy
Luminous Efficacy is a measure of how well a light source produces visible light and the ratio of luminous flux (lumens, lm) to power (W). Luminous efficacy can be expressed as
η = Φ / P (1)
η = luminous efficacy
Φ = luminous flux - the quantity of light emitted by a light source (lumen, lm)
P = power (W)
Light Types and typical Luminous Efficacy:
Light | Luminous Efficacy - η - (lumens/W) |
Fluorescent lamp | 45 - 75 |
Halogen lamp | 16 - 24 |
High pressure sodium vapor lamp | 85 - 150 |
LED lamp | 30 - 90 |
Mercury vapor lamp | 35 - 65 |
Metal halide lamp | 75 - 100 |
Tungsten incandescent light bulb lamp | 12 - 18 |
Luminous Intensity describes the quantity of light that is radiated in a particular direction. This is a useful measurement for directive lighting elements such as reflectors. It can be expressed as
I = Φ / Ω (2)
I = luminous intensity (lm/sr, candela, cd)
Φ = luminous flux (lumen, lm)
Ω = solid angle (the amount of the field of view from some particular point that a given object covers) into which luminous flux is emitted (steradians, sr)
Example Luminous Efficacy - Power required to a LED Lamp vs. a Tungsten Incandescent Lamp
A specific application requires 500 lumens of light.
The required power to a tungsten incandescent lamp with luminous efficacy 15 lm/W can be calculated by modifying (1)
P = Φ / η
= (500 lm) / (15 lm/W)
= 33 W
The required power to a LED lamp with luminous efficacy 70 lm/W can be calculated by modifying (1) to
P = Φ / η
= (500 lm) / (70 lm/W)
= 7.1 W
• Electrical
Electromagnetic Spectrum
The electromagnetic spectrum with wavelengths and frequencies.
Heat Gain from Lights
Heat contributed by lights may have major impact on air-condition systems.
Illuminance - Recommended Light Levels
Working activities and light levels - required illuminance.
LENI - Lighting Energy Numeric Indicator
Energy consumption of lighting systems
Lights vs. Power Installation
Lights vs. power installations in common types of buildings and rooms.
Materials - Light Reflecting Factors
Light reflecting factor materials.
Optical Distance Law
Geometric dilution of light vs. distance.
Refractive Index common Liquids, Solids and Gases
Some common liquids, solids, and gases and their refractive indexes.
