Optical Distance Law
The illumination intensity on a surface is inversely proportional to the square of its distance from the light source and can be expressed as
E = Φ / d2 (1)
E = light intensity, illumination (lux, lumen/m2)
Φ = the quantity of light emitted by a lamp or a light source - luminous flux (lumen, lm)
d = distance from light source (m)
Since
E1 d12 = E2 d2 2
= constant (2)
(2) can be modified to
E1 / E2 = d2 2 / d12 (2b)
Example - Illumination Intensity from a Lamp at distance
The illumination intensity from lamp with luminance 10000 lumens at distance 2 m can be calculated with (1) as
E1 = (10000 lumens) / (2 m)2
= 2500 lux
The illumination intensity at distance 5 m can be calculated by modifying (2b) to
E2 = E1 d12 / d2 2
= (2500 lux) (2 m)2 / (5 m)2
= 400 lux
Cosine law of Illumination
E = (Φ / d2) cos(θ) (3)
θ = angle between light source vertical line and sight line
• Basics
• Mathematics
Absorbed Solar Radiation
Solar radiation absorbed by various materials.
Electromagnetic Spectrum
The electromagnetic spectrum with wavelengths and frequencies.
Heat Gain from Lights
Heat contributed by lights may have major impact on air-condition systems.
Illuminance - Recommended Light Levels
Working activities and light levels - required illuminance.
Lights vs. Power Installation
Lights vs. power installations in common types of buildings and rooms.
Ligths - Color Temperatures
Light sources and their color irradiation in degrees Kelvin.
Luminous Efficacy
The visible light produced by light sources.
Materials - Light Reflecting Factors
Light reflecting factor materials.
Refractive Index common Liquids, Solids and Gases
Some common liquids, solids, and gases and their refractive indexes.
Sound Propagation - the Inverse Square Law
Doubling of the distance from a noise source reduces the sound pressure level with 6 decibel.
