Solar Radiation - Daily Surface Energy
Solar energy accumulated on south faced horizontal to vertical tilted surfaces on the northern hemisphere latitude 0oN, 30oN and 60oN - are indicated in the diagrams below:
Solar Radiation - Latitude 0oN
  • 1 MJ = 0.278 kWh = 239 kcal = 948 Btu
  • 1 m2 = 1550 in2 = 10.764 ft2
Solar Radiation - Latitude 30oN
Solar Radiation - Latitude 60oN
At equator there may be enough radiation in winter time to consider year-round applications. In the northern hemisphere we have to look for applications that requires energy mainly in summer time.
Environment
Absorbed Solar Radiation
Solar radiation absorbed by various materials.
Acceleration of Gravity vs. Latitude and Elevation
Acceleration of gravity due to latitude and elevation above sea level.
Glazing Materials - Optical Properties
Optical properties of commonly used glazing materials.
Global Temperature Trend
Global temperature trend year 1880 - 2015.
Latitude and Longitude Converter: Convert Between Degrees, Minutes, Seconds, and Decimal Units
Convert between Degrees, Minutes and Seconds and Decimal Units (or vice versa).
Radiation - Surface Emissivity Coefficients
Radiation emissivity of common materials like water, ice, snow, grass and more.
Radiation Heat Transfer
Solar Heat Transmission and Type of Glass
Relative solar heat transmission through different types of glass windows
Solar Heat Transmission through Windows
Solar heat gain through windows with roller shades, vertical blinds and Venetian blinds
Solar Radiation through Windows
Heat from sun transmitted through windows.
Sun Charts
Online solar chart creator.
Surface Radiation Absorptivity
Radiation surface absorptivity.
UTM to Latitude and Longitude Converter: Convert UTM Coordinates to Geographic Coordinates
Free online UTM to Latitude and Longitude coordinates converter.
