Solar Heat Transmission and Type of Glass
Heat transmission through different types of glass windows compared to ordinary single glass window:
Air Conditioning
Float Glass - Weight vs. Thickness
Weight of float glass.
Radiation Heat Transfer
Solar Radiation - Daily Surface Energy
Daily surface energy from solar radiation.
Windows - Inside Condensation
Water condensation on inside glass windows surfaces vs. outside temperature and inside temperature and humidity.
