Windows - Inside Condensation
The influence of
  • outside temperature
  • inside air relative humidity (for inside air dry bulb temperature at 65 o F (18.3 o C))
on the condensation on inside surface of glass windows are indicated in the charts below:
Windows - Overall Heat Transfer Coefficients U
  • Single glass window : U = 1.13 (Btu/ft 2 o F hr) =  6 ( W/m 2 o C )
  • Double sealed glass window : U = 0.58 (Btu/ft 2 o F hr) =  3 ( W/m 2 o C )
Example - Condensation temperature on a window surface
  • indoor relative humidity of 50%
  • window with single glass with U-value aprox. 6 (W/m 2 o C), 1.13 (Btu/ft 2 o F hr)
Based on the diagram above condensation on the inside of the glass starts when the outside air temperature is 6 o C (43 o F) .
Heating
Heating systems - capacity and design of boilers, pipelines, heat exchangers, expansion systems and more.
Float Glass - Weight vs. Thickness
Weight of float glass.
Heat Loss from Buildings
Overall heat transfer loss from buildings - transmission, ventilation and infiltration.
Solar Heat Transmission and Type of Glass
Relative solar heat transmission through different types of glass windows
Solar Heat Transmission through Windows
Solar heat gain through windows with roller shades, vertical blinds and Venetian blinds
Transmission Heat Loss through Building Elements
Heat loss through common building elements due to transmission, R-values and U-values - imperial and SI units.
