Types of Shading | Fraction of Gain through Unshaded Window |
Unshaded Window | 1.00 |
Inside roller shade - half-drawn | 0.80 |
Inside roller shade - fully-drawn | 0.62 |
Inside venetian blind | 0.65 |
Canvas awning | 0.30 |
Outside shading screen - solar altitude 20o | 0.38 |
Outside shading screen - solar altitude 30o | 0.25 |
Outside shading screen - solar altitude 40o | 0.18 |
Solar radiation absorbed by various materials.
Optical properties of commonly used glazing materials.
Radiation emissivity of common materials like water, ice, snow, grass and more.
Daily surface energy from solar radiation.
Heat from sun transmitted through windows.
Online solar chart creator.
The Wet Bulb Globe Temperature can be used to measure the general Heat-Stress index.
Water condensation on inside glass windows surfaces vs. outside temperature and inside temperature and humidity.
