Acceleration of Gravity vs. Latitude and Elevation
Acceleration of gravity at sea level and elevation related to north-south position on earth (degrees latitude):
Acceleration of Gravity vs. Latitude and Elevation (m/s2)
Acceleration of Gravity vs. Latitude (ft/s2)
Example - Time for Falling Object to Hit the Ground on the Pole or on the Equator
The distance traveled after some time by a free falling object can be expressed as:
s = 1/2 ag t2
s = distance (m, ft)
ag = acceleration of gravity (m/s2, ft/s2)
t = time (s)
The acceleration of gravity is stronger at the poles than at equator and the equation above can be modified to
t = (2 s / ag)1/2
The time for an object at level 1 m to hit the ground on the pole can be calculated as:
t = (2 (1 m) / (9.832 m/s2))1/2
= 0.4510 s
The time for an object at level 1 m to hit the ground on the equator can be calculated as:
t = (2 (1 m) / (9.78 m/s2))1/2
= 0.4522 s
Example - The Weight of a Large Man in Canada vs. Venezuela
The acceleration of gravity in Canada at latitude 60 degrees is approximately 9.818 m/s2 and the acceleration of gravity in Venezuela at latitude 5 degrees is approximately 9.782 m/s2.
The weight - or gravity force - of a large man with mass 100 kg in Canada can be calculated as
Fg = (100 kg) (9.818 m/s2)
= 982 N
The weight the man in Venezuela can be calculated as
Fg = (100 kg) (9.782 m/s2)
= 978 N
Acceleration of gravity and Newton's Second Law - SI and Imperial units.
Distance between 3D Points
Distance between two points in a three dimension x, y and z coordinate system - online calculator.
Latitude and Longitude Converter
Convert between Degrees, Minutes and Seconds and Decimal Units (or vice versa).
Solar Radiation - Daily Surface Energy
Daily surface energy from solar radiation.
Universal Gravitational Law
Gravitational attraction between two objects vs. mass of the objects and the distance between them.
UTM to Latitude and Longitude Converter
Free online UTM to Latitude and Longitude coordinates converter.
