Thermal conductivity is a material property that describes ability to conduct heat. Thermal conductivity can be defined as
The thermal conductivity of water depends on temperature and pressure as shown in the figures and tables below:
See also other properties of Water at varying temperature and pressure : Boiling points at high pressure, Boiling points at vacuum pressure, Density and specific weight, Dynamic and kinematic viscosity, Enthalpy and entropy, Heat of vaporization, Ionization Constant, pKw , of normal and heavy water, Melting points at high pressure, Prandtl number, Properties at Gas-Liquid Equilibrium Conditions, Saturation pressure, Specific gravity, Specific heat (heat capacity), Specific volume, Thermal diffusivity and Vapour pressure at gas-liquid equilibrium, and Thermophysical properties at standard conditions ,
as well as thermal conductivity o f air, ammonia, butane, carbon dioxide, ethylene, hydrogen, methane, nitrogen and propane . For thermal conductivity of construction materials, see related documents at the bottom of the page.
Thermal conductivity of water at given temperatures (°C) and 1 bara:
| State of water | Temperature | Thermal conductivity | ||
| (°C) | (mW/m K) | (kcal(IT)/(h m K)) | (Btu(IT)/(h ft °F)) | |
| Liquid | 0.01 | 555.75 | 0.4779 | 0.3211 |
| 10 | 578.64 | 0.4975 | 0.3343 | |
| 20 | 598.03 | 0.5142 | 0.3455 | |
| 30 | 614.50 | 0.5284 | 0.3551 | |
| 40 | 628.56 | 0.5405 | 0.3632 | |
| 50 | 640.60 | 0.5508 | 0.3701 | |
| 60 | 650.91 | 0.5597 | 0.3761 | |
| 70 | 659.69 | 0.5672 | 0.3812 | |
| 80 | 667.02 | 0.5735 | 0.3854 | |
| 90 | 672.88 | 0.5786 | 0.3888 | |
| 99.6 | 677.03 | 0.5821 | 0.3912 | |
| Gas | 100 | 24.57 | 0.0211 | 0.0142 |
| 125 | 26.66 | 0.0229 | 0.0154 | |
| 150 | 28.83 | 0.0248 | 0.0167 | |
| 175 | 31.09 | 0.0267 | 0.0180 | |
| 200 | 33.43 | 0.0287 | 0.0193 | |
| 225 | 35.85 | 0.0308 | 0.0207 | |
| 250 | 38.34 | 0.0330 | 0.0222 | |
| 275 | 40.91 | 0.0352 | 0.0236 | |
| 300 | 43.53 | 0.0374 | 0.0252 | |
| 350 | 48.98 | 0.0421 | 0.0283 | |
| 400 | 54.65 | 0.0470 | 0.0316 | |
| 450 | 60.52 | 0.0520 | 0.0350 | |
| 500 | 66.58 | 0.0573 | 0.0385 | |
| 550 | 72.81 | 0.0626 | 0.0421 | |
| 600 | 79.17 | 0.0681 | 0.0457 | |
| 700 | 92.28 | 0.0794 | 0.0533 | |
| 800 | 105.81 | 0.0910 | 0.0611 | |
| 900 | 119.67 | 0.1029 | 0.0691 | |
Thermal conductivity of water at given temperatures (°F) and 14.5 psia:
| State of water | Temperature | Thermal conductivity | |||
| (°F) | (Btu(IT)/(h ft °F)) | (Btu(IT) in/(h ft2°F)) | (mW/m K) | (×10-3 cal(IT)/(s cm2K)) | |
| Liquid | 32 | 0.3211 | 3.853 | 555.73 | 1.327 |
| 40 | 0.3273 | 3.927 | 566.39 | 1.353 | |
| 60 | 0.3408 | 4.089 | 589.80 | 1.409 | |
| 80 | 0.3520 | 4.225 | 609.30 | 1.455 | |
| 100 | 0.3615 | 4.338 | 625.62 | 1.494 | |
| 120 | 0.3694 | 4.433 | 639.35 | 1.527 | |
| 140 | 0.3761 | 4.513 | 650.91 | 1.555 | |
| 160 | 0.3817 | 4.580 | 660.57 | 1.578 | |
| 180 | 0.3862 | 4.635 | 668.45 | 1.597 | |
| 200 | 0.3897 | 4.677 | 674.49 | 1.611 | |
| 211.3 | 0.3912 | 4.694 | 677.03 | 1.617 | |
| Gas | 212 | 0.0142 | 0.170 | 24.57 | 0.059 |
| 250 | 0.0152 | 0.183 | 26.33 | 0.063 | |
| 300 | 0.0166 | 0.199 | 28.73 | 0.069 | |
| 350 | 0.0181 | 0.217 | 31.25 | 0.075 | |
| 400 | 0.0196 | 0.235 | 33.86 | 0.081 | |
| 450 | 0.0211 | 0.254 | 36.56 | 0.087 | |
| 550 | 0.0244 | 0.293 | 42.24 | 0.101 | |
| 600 | 0.0261 | 0.313 | 45.20 | 0.108 | |
| 650 | 0.0279 | 0.334 | 48.24 | 0.115 | |
| 700 | 0.0297 | 0.356 | 51.35 | 0.123 | |
| 750 | 0.0315 | 0.378 | 54.52 | 0.130 | |
| 800 | 0.0334 | 0.400 | 57.76 | 0.138 | |
| 900 | 0.0372 | 0.447 | 64.41 | 0.154 | |
| 1000 | 0.0412 | 0.494 | 71.27 | 0.170 | |
| 1100 | 0.0453 | 0.543 | 78.32 | 0.187 | |
| 1200 | 0.0494 | 0.593 | 85.53 | 0.204 | |
| 1400 | 0.0580 | 0.696 | 100.35 | 0.240 | |
| 1600 | 0.0668 | 0.802 | 115.63 | 0.276 | |
• Steam and Condensate
• Thermodynamics
• Thermodynamics
• Water Systems
Benzene Liquid - Thermal Properties
Properties like density, specific heat, thermal conductivity, dynamic viscosity and Prandtl number.
Calcium Silicate Insulation
Thermal conductivity of calcium silicate insulation - temperature and k-values.
Online calculator, figures and table showing thermal conductivity of carbon dioxide, CO2, at temperatures ranging from -50 to 775 °C (-50 to 1400 °F) at atmospheric and higher pressure - Imperial and SI Units.
Conductive Heat Transfer
Fiberglass Insulation
Thermal conductivity of fiberglass insulation - temperature and k-values.
Typical heat exchanger materials and their thermal conductivities.
Heat Transmission Loss through Building Elements
Heat loss through common building elements due to transmission, R-values and U-values - imperial and SI units.
Online calculator, figures and table showing thermal conductivity of methane, CH4, at temperatures ranging from -160 to 725 °C (-260 to 1300 °F) at atmospheric and higher pressure - Imperial and SI Units.
Octane Liquid - Thermal Properties
Density, specific heat, thermal conductivity and more.
Overall Heat Transfer Coefficient: Definitions, Values & Applications
Perlite Insulation
Pipes and Cylinders - Conductive Heat Loss
Conductive heat losses through cylinder or pipe walls.
Thermal conductivity of plastics.
Polyurethane Insulation
Thermal Conductivity of Common Materials - Solids, Liquids and Gases
Thermal conductivity of various common materials, including metals, gases, and building materials. Essential data for engineers, architects, and designers working with heat transfer and insulation.
Thermal Conductivity Units Converter
Toluene Liquid - Thermal Properties vs. Temperature
Water - Dynamic and Kinematic Viscosity at Various Temperatures and Pressures
Ionization constant (= dissociation constant = self-ionization constant = ion product = autoprotolysis constant ) of water and heavy water, given as function of temperature (°C and °F) in figures and tables.
Water Properties: Vaporization Heat vs. Temperature - Charts and Calculator
Water Vapor Saturation Pressure: Data, Tables & Calculator
