Octane Liquid - Thermal Properties
Thermal properties of Octane:
Temperature
- t -
(oC)
Density
- ρ -
(kg/m3)
Specific Heat
- cp -
(kJ/kg K)
Thermal Coductivity
- λ -
(W/m K)
Dynamic Viscosity
10-6
- η -
(Pa s)
Prandtl's no.
-25 738 2.064 0.144 1020 14.62
0 719 2.131 0.137 714 11.11
Octane is a hydrocarbon and an alkane with the chemical formula C8H18, and the condensed structural formula CH3(CH2)6CH3.
  • 1 kg/m3 = 0.0624 lb/ft3
  • 1 kJ/kgK = 0.2389 Btu/lbmoF
  • 1 W/(m K) = 6.935 (Btu in)/(ft² h °F)
  • 1 Pa s (N s/m2) = 10 P (Poise) = 103 cP = 0.1020 kp s/m2 = 0.6721 lb/(ft s)
Material Properties
Properties of alternative fuels like biodiesel, E85, CNG and more.
Combustion Heat
Flash Points - Liquids
The flash points for some common liquids and fuels.
Heating Values of Fuel Gases
Combustion heat values for gases like acetylene, blast furnace gas, ethane, biogas and more - Gross and Net values.
Liquids - Dynamic Viscosities
Absolute (dynamic) viscosity values for some common fluids.
