Liquids - Dynamic Viscosities
Absolute or dynamic viscosities for some common liquids at temperature 300 K are indicated below:
Fluids - Dynamic Viscosities
FluidAbsolute Viscosity
(N s/m2, Pa s)(centipoise, cP)(10-4lb/s ft)
Acetic acid 0.001155 1.155 7.76
Acetone 0.000316 0.316 2.12
Alcohol, ethyl (ethanol) 0.001095 1.095 7.36
Alcohol, methyl (methanol) 0.00056 0.56 3.76
Alcohol, propyl 0.00192 1.92 12.9
Benzene 0.000601 0.601 4.04
Blood 0.003 - 0.004
Bromine 0.00095 0.95 6.38
Carbon Disulfide 0.00036 0.36 2.42
Carbon Tetrachloride 0.00091 0.91 6.11
Castor Oil 0.650 650
Chloroform 0.00053 0.53 3.56
Decane 0.000859 0.859 5.77
Dodecane 0.00134 1.374 9.23
Ether 0.000223 0.223 1.50
Ethylene Glycol 0.0162 16.2 109
Trichlorofluoromethane refrigerant R-11 0.00042 0.42 2.82
Glycerine 0.950 950 6380
Heptane 0.000376 0.376 2.53
Hexane 0.000297 0.297 2.00
Kerosene 0.00164 1.64 11.0
Linseed Oil 0.0331 33.1 222
Mercury 0.0015 1.53 10.3
Milk 0.003
Octane 0.00051 0.51 3.43
Phenol 0.0080 8.0 54
Propane 0.00011 0.11 0.74
Propylene 0.00009 0.09 0.60
Propylene glycol 0.042 42
Toluene 0.000550 0.550 3.70
Turpentine 0.001375 1.375 9.24
Water, Fresh 0.00089 0.89 6.0
Liquids - Temperature and Dynamic Viscosities
  • Acetic acid
    Acetone
    Aniline
    Benzene
    Bromobenzene
    N-Butane
    Carbon disulphide
    Carbon dioxide
    Carbon tetrachloride
    Chloroform
    Di-ethyl ether
  • Ethanol
    Ethyl acetate
    Ethyl formate
    N-Hexane
    n-Hexadecane.
    Mercury
    Methanol
    Nitrobenzene
    N-Octane
    Oil, castor
    Oil, olive
    N-Pentane
    N-Propane
    Sulphuric acid
    Toluene
Fluid Mechanics
Material Properties
Viscosities
Blood Sugar Units
Convert between blood sugar units.
Crude Oil Viscosity vs. Gravity
Viscosity at 20°C/68°F and 50°C/122°F for more than 120 crudes is shown as function of specific gravity@15°C/60°F.
Dynamic (Absolute) Viscosity - Converting Chart
Convert dynamic viscosity values between units like Poiseuille - Poise - centiPoise and more.
Engine & Gear Oil - Recommended Viscosity vs. Outside Temperature
Oil viscosity vs. temperature.
Octane Liquid - Thermal Properties
Density, specific heat, thermal conductivity and more.
Viscosities and densities of SAE Grade oils.
Steam - Viscosity vs. Pressure
Absolute viscosity of steam at pressure ranging 1 - 10000 psia.
Steel Pipes - Viscous Liquid Flow and Friction Loss
Friction loss in schedule 40 steel pipe with viscous liquids - viscosities ranging from water to oil.
Toluene Liquid - Thermal Properties vs. Temperature
Viscosity Converter: Convert Between Dynamic & Kinematic Viscosity
Water - Absolute (Dynamic) Viscosity vs. Temperature and Pressure
Absolute viscosity for water in centipoises for temperatures between 32 - 200oF.
